Brake warning...
Old Oct 15, 2014 | 07:36 PM
slimjimtel's Avatar
slimjimtel
Default Brake warning...
I got the attached warning today on my 2010 LS600. The pedal felt a little soft after the warning. It kept popping off and on, dinging every 30-40 seconds.
I checked the brake fluid, it was full. Car has 36k
I had it towed in to Lexus and they couldn't get the warning to come back up.
Anyone else have this?
Old Oct 15, 2014 | 07:40 PM
slimjimtel's Avatar
slimjimtel
Here is the warning I got.
Old Oct 16, 2014 | 05:01 AM
wbrian63's Avatar
wbrian63
Parking brake system, if it's the same on a 600H as a 460 is separate and apart from the regular braking system. As such, your feeling that the pedal was "soft" would seem to be more of a perception that something was different because of the warning message you saw.
The parking brake is an electro-mechanical system that uses "old style" brake shoes that grip the inside of the rear brake discs. Activation is via a servo motor at the rear of the car.
My guess is that it didn't fully release when you put the car into gear. Assuming the tow driver drove the car up onto the flat bed - when the transmission was put in Park, that put a nice "load" on the brake shoes given the angle of the incline. When the car was removed from the tow truck at the dealer, the brakes fully released and the problem didn't reoccur.
If it happens again, try cycling the parking brake manually - push on the button to set the brake, then pull on it to release.
Possibly there's some grit or corrosion that's preventing the cables and/or brakes from releasing fully/smoothly.
Old Oct 16, 2014 | 06:42 AM
is150's Avatar
is150
Did the message appear after engaging or disengaging the emergency brake? Or while driving?
Old Oct 16, 2014 | 06:35 PM
slimjimtel's Avatar
slimjimtel
Well, they couldn't replicate it. I engaged and disengaged the parking brake probably 10 times before it got towed. Still got the message.
They returned the car to me, all seems well. I will keep an eye on it. I did get s low battery warning on my smart start, called the dealer and said, your running my battery down!
Wallander
RX - 3rd Gen (2010-2015)
Jan 20, 2017 10:11 AM
Luke27617
Jan 28, 2012 10:25 PM
conekiller
Suspension and Brakes
32
Aug 13, 2007 05:53 PM
IStreefidy
Nov 14, 2006 04:37 AM
Lboogie300
May 23, 2006 06:32 AM
