failed trunk opener
Old Sep 9, 2013 | 06:51 AM
rziez's Avatar
rziez
Default failed trunk opener
I tried to jam four sets of golf clubs in the trunk of my 2008 460. Had to push the trunk to close it - A MISTAKE. The remotes then to open the trunk from the dash and and the trunk lid would beep but the trunk would not open. Used the manual key on top of the license plate to finally open the trunk and that worked BUT then the remotes (dash and back of car) would not work - would beep but wouldn't open the trunk. Then, checked the fuse for the opener in the trunk compartment and it was OK..
FINALLY - disconnected the ground from the battery for 10 seconds( battery difficult to get to!!) and that solved the problem.
Old Sep 9, 2013 | 11:51 AM
darksands's Avatar
darksands
For trunk issues it's usually that or check the valet trunk disable switch in the glove compartment.
Old Sep 9, 2013 | 05:14 PM
Nospinzone's Avatar
Nospinzone
Yup. Welcome to the forum rziez. Just as an FYI, if you had come here first and did a search, you would have found that solution out in seconds.
nmumford
Mar 10, 2019 04:27 PM
Tmac334
GS - 1st Gen (1993-1997)
Sep 30, 2018 04:17 PM
peasodos
Feb 15, 2017 08:16 AM
Z0SICK
Jan 19, 2014 12:44 PM
PoxLi
Nov 4, 2013 05:15 PM
