turn signal bulb replacement-outside rear view mirrot
The turn signal indicator in my right side outside mirror(LS-460) went out yesterday.I took the mirror apart this morning hoping to replace the bulb .After getting it disassembled down to a subassembly,i'm not sure whether the bulb is replaceable or the subassembly has to be replaced.Has anyone replaced the bulb? tx in advance
When I put the 12v across the terminals,the whole assembly lite up--not just the yellow turn signal part.of the lens,.I've never seen the whole lens lit. What switch position will light the whole assembly?My wife has an es-350 with the same type mirror and I couldn't get hers to light either. tx's for the help
finally got around to trouble shooting the problem and found out it really wasn't a problem at all. The entire comet light comes on when the door open/close operation is activated by the remote or door handle.
Red Green
GX - 1st Gen (2003-2009)
Sep 12, 2010 12:05 PM
