Last edit by: IB Advertising
Browse all: Tires and Wheels Guide
- Tires General Information and Specs
Important information to help you understand your Lexus
LS 460/600 Wheel & Tire Information Details Thread
#121
LS Year/Model: 2016
Wheel Brand: BBS
Wheel Model: CI-R
Wheel Size Front: 20
Wheel Size Rear: 20
Wheel Finish: Platinum Silver
Lip size front (if applicable):
Lip size rear (if applicable):
Lip finish (if applicable):
Offset Front: +32
Offset Rear: + 40
Hub Bore size (if known):
Hub Centric Rings Required? Y/N: N
Tire Size Front: 245/40/20
Tire Size Rear: 255/40/20
Tire Air Pressure Preference:38
Suspension:Stock
Fenders Rolled/Altered: No
Does the setup rub?: No
Wheel Brand: BBS
Wheel Model: CI-R
Wheel Size Rear: 20
Offset Front: +32
Offset Rear: + 40
Suspension:Stock
#122
LS Year/Model: 2013 F Sport RWD
Wheel Brand: Rohana
Wheel Model: RFX10
Wheel Size Front: 21 X 9
Wheel Size Rear: 21 X 10.5
Wheel Finish: Brushed Titatnium
Offset Front: 35
Offset Rear: 40
Hub Centric Rings Required? Y/N: Y
Tire Size Front: 245X35X21
Tire Size Rear: 285X30X21
Tire Make/Model: Michelin Pilot Super Sport
Tire Air Pressure Preference: 40
Suspension: Data Systems Front 3 down, Rear 1 Down
Fenders Rolled/Altered: NoDoes the setup rub?: No
Wheel Brand: Rohana
Wheel Model: RFX10
Offset Front: 35
Offset Rear: 40
bigsherv (07-29-19)
#123
LS Year/Model: 2016 LS 460 F Sport RWD
Wheel Brand: Asanti
Wheel Model: ABL 24
Wheel Size Front: 22x9
Wheel Size Rear: 22x9
Wheel Finish: Brushed Silver
Lip finish (if applicable): Stainless
Offset Front: +32
Offset Rear: +32
Hub Bore size (if known): 74.1
Tire Size Front: 265/30 22
Tire Size Rear: 265/30 22
Tire Make/Model: Continental ExtremeContact DWS 06
Tire Air Pressure Preference: 40PSI
Suspension: Stock
Wheel Brand: Asanti
Wheel Model: ABL 24
Offset Front: +32
Offset Rear: +32
Suspension: Stock
Zetascry (12-24-20)
#124
LS Year/Model: 2009 Base
Wheel Brand: Verde
Wheel Model: Insignia
Wheel Finish: Hyper Silver
Lip finish (if applicable): none
Offset Front: +35
Offset Rear: +35
Tire Size Front: 255/30 22
Tire Size Rear: 255/30 22
Suspension: Stock
Wheel Brand: Verde
Offset Front: +35
Offset Rear: +35
Suspension: Stock
Ragnar1348 (07-25-20)
#125
LS Year/Model: 2014 460 RWD
Wheel Brand: Rohanna
Wheel Model: RC10
Wheel Size Front: 20x9
Wheel Size Rear: 20x10
Wheel Finish: Machined Silver
Lip size front (if applicable): N/A
Lip size rear (if applicable): N/A
Lip finish (if applicable): Chrome
Offset Front: 35mm
Offset Rear: 40mm
Hub Centric Rings Required? Y/N: Yes
Tire Size Rear: 275/35/20
Tire Make/Model: Continental Extreme Contact DWS06
Tire Air Pressure Preference: 34psi
Suspension: Stock
Wheel Model: RC10
Offset Front: 35mm
Offset Rear: 40mm
Suspension: Stock
snakehead (04-21-21)
#126
LS Year/Model: 2011 460 LWB
Wheel Brand: XIX
Wheel Model: X23
Wheel Size Rear: 20x10.5
Offset Front:
Offset Rear:
Hub Centric Rings Required? Y/N: No
Tire Size Front: 245/25/22
Tire Size Rear: 295/25/22
Tire Make/Model: Zenna Argus
Tire Air Pressure Preference: 40psi
Suspension: Stock
Wheel Brand: XIX
Wheel Model: X23
Offset Front:
Offset Rear:
Suspension: Stock
#127
LS Year/Model: 2010 460 LWB
Wheel Brand: XO
Wheel Model: Moscow
Wheel Size Rear: 22x10.5
Wheel Finish: Silver
Lip finish (if applicable): N/A
Offset Front:
Offset Rear:
Tire Size Front: 255/30/22
Tire Make/Model: Lexani LX-Twenty performance radial tire
Suspension: Stock Air
Does the setup rub?: Yes rubs on passenger side rear over bumps and wide turns
Wheel Brand: XO
Wheel Model: Moscow
Offset Front:
Offset Rear:
VelvetJonz (10-12-20)
#128
LS Year/Model: 2008 LS460 SWB RWD
Wheel Brand:Inovit
Wheel Model:Haste
Wheel Size Front:20x8.5
Wheel Size Rear:20x10
Wheel Finish:chrome/brushed Aluminum
Lip size front (if applicable):2in
Lip size rear (if applicable):4in
Lip finish (if applicable):Chrome
Offset Front:
Offset Rear:
Hub Bore size (if known): Too big.
Hub Centric Rings Required? Y/N: Y& N Custom spacers with hub.
Tire Size Front:285/40-20
Tire Size Rear:265/45-20
Tire Make/Model:Lexani X10
Tire Air Pressure Preference:36
Suspension: standard
Fenders Rolled/Altered:No
Does the setup rub?:No
Pics Below:
Rear
Wheel Brand:Inovit
Wheel Model:Haste
Offset Front:
Offset Rear:
Pics Below:
Rear
#129
LS Year/Model: 2014 LS460 AWD F-Sport
Wheel Brand: Rohana
Wheel Model: RFX10
Wheel Size Front: 21x9
Wheel Size Rear: 21x10.5
Offset Front: +35
Offset Rear: +40
Tire Size Front: 255/35/21
Tire Size Rear: 295/30/21
Tire Make/Model: Michelin PS 4S
Tire Air Pressure Preference: 37-41
Suspension: Factory Air
Pics Below:
Wheel Brand: Rohana
Wheel Model: RFX10
Offset Front: +35
Offset Rear: +40
Pics Below:
#130
Greetings fellow 4th Gen owners. Just a heads up. Quite a few posts will be deleted in the coming days for not following the numerous requests about how to contribute to this thread. This thread was created many years ago by me as a way to capture wheel and tire information in one place using a template theme as the standard so the thread could be used exclusively for reference. Over time, threads have been replied to or random comments added which quickly clutters things up significantly. As a moderator who has spent many hours contributing to this site for years, my goal is to help fellow owners by trying to provide information in the most helpful and efficient way. With that said, if you have a post in here that does not have the template with specs of your set up, it will be removed. And yes If, I've removed some of my posts that are not reminders on using the template If you have questions about a poster's setup, please private message them. For those of you that have contributed to this thread, it is very much appreciated. Thanks for understanding folks!!!
Zetascry (12-18-20)
#131
Hi Amack,
I like the XO NY sets that you have! I read somewhere online that the lips bent or damaged easily..... want to hear the opinion from a fellow member. Is that true?
Thanks,
T
Thanks,
T
#132
the lip has a sleeve that does “ding” easily but if your careful it’ll be fine.
they can also be fixed pretty economically.
I do love them and used them in my 2015 LS460L also.
#133
hi and thanks. I can’t say they bend easily as my issues were because of poor choice in tires. Ome cracked but it was a bad pothole and weak sidewall tires.
#134
My French Taxi...
LS Year/Model: 2008 / 600HL Wellness
AWD or RWD: AWD
Wheel Brand: AZ
Wheel Model: STORM
Wheel Size Front: 9"
Wheel Size Rear: 10,5"
Wheel Finish:
Offset Front: 32
Offset Rear: 35
Tire Size Front: 245/30/22
Tire Make/Model: NEXEN N/FERA
Tire Air Pressure Preference: 2.5 Kg
Suspension: original air must be equipped with a data system lowering module later
Fenders Rolled/Altered: no
Does the setup rub?: no
AWD or RWD: AWD
Wheel Brand: AZ
Wheel Model: STORM
Wheel Finish:
Offset Front: 32
Offset Rear: 35
#135
Finally I can post some pictures in this topic, it took me 2 years to search something which was avalible for my car and I liked, since overhere there is almost nothing to get. Also nothing on stock. Therefor it was a very big gamble since I only had a drawing and a small picture of the color, but I'm happy with the outcome, so here we go:
LS Year/Model: 2007 LS460
AWD or RWD: RWD
Wheel Brand: Work
Wheel Model: Gnosis HR201
Wheel Size Front: 21'' 9J
Wheel Size Rear: 21'' 10.5J
Wheel Finish: Titanium Gold
Lip finish (if applicable): Step lip Buffed
Offset Front: +32
Offset Rear: +36
Tire Size Front: 245 / 40 / 21
Tire Size Rear: 285 / 35 / 21
Tire Make/Model: Pirelli P Zero PZ4
Tire Air Pressure Preference: 2.5 bar
Suspension: Standard Air Suspension
Does the setup rub? : No
Pics below:
AWD or RWD: RWD
Wheel Brand: Work
Offset Front: +32
Offset Rear: +36
Pics below:
Last edited by FDD; 04-06-21 at 09:27 AM. Reason: The pics below was below the pictures...
