Minor Vibration at Idle
Old Oct 19, 2011 | 10:32 PM
ALeX300's Avatar
ALeX300
hmmm I have a very slight vibration when in Park(rpms about 650) but i did have the TSiB for hesitation performed and vibration is still here. Not that its bothering me as much as a loose glovebox....
Old Oct 20, 2011 | 08:10 AM
quensx's Avatar
quensx
Originally Posted by I8ABMR
I had the same issue with my LS when I got it. There is a TSIB on it. They reprogrammed something in the ECU I believe. All I know is that it made a big difference. The idle is still smoother with the AC on because of the higher rpm, but it helped a lot. I would tell them that there is a TSIB.
Now that I think of it , I am pretty sure the TSIB may have been related to a hesitation issue with the LS when taking off from a dead stop. There is a solution to this
I had the hesitation on acceleration TSIB performed. As a matter of fact, I think I noticed this vibration more so after the TSIB rather than before. Well, the weather has gotten a lot more cooler since then, and I think I probably had the AC running pretty much all the time back then, vs now, I hardly have the AC running.
Old Feb 3, 2012 | 08:41 PM
realperson's Avatar
realperson
My LS600 has no rpm and whole car vibrates on idol every few minutes, so work that one out
Old Feb 3, 2012 | 09:27 PM
LS430black's Avatar
LS430black
Seems that mine is an odd one. The vibration starts, pretty hard, at D and without pressing the gas pedal, then go away when accelerating. Can anyone work out this issue? When at D, RPM is around 500. At idle, it's normal.
Dema's Avatar
Dema
Yes, this vibration drives me crazy. Wort thing is that people make laugh on my Lexus, comparing to my Mercedes which is completely still and much less expensive. Anyway I keep hope that Lexus engineers will find a solution.
Old Feb 15, 2018 | 10:49 AM
Dolph1's Avatar
Dolph1
I was just sitting in my 13 ls awd with the car running and in park for 15 minutes. RPMs were at 9k. Every once in a while I felt a vibration come through the lumbar. It looked like the RPM gauge moved ever so slightly when this happened but was not very noticeable. Is this normal to you all? I have only put about 250 miles on the car since I purchased it as a certified end of Dec. Car has 37k on it.
Old Feb 17, 2018 | 03:44 PM
ALK's Avatar
ALK
Some say that the throttle body needs adjustment for the sensor or replacement of the sensor . .
SC3coupe
Dec 6, 2024 01:44 PM
mattylex77
19
Sep 13, 2014 04:45 AM
Lexus082
Jul 31, 2007 09:23 PM
clivej
Jan 9, 2004 10:30 PM
