Touchy Brakes on the LS460
Old Nov 21, 2010 | 10:09 AM
blackz405's Avatar
blackz405
Exclamation Touchy Brakes on the LS460
I just got a used 2007 LS and found the brake is super sensitive. If I press the brake pedal very quickly, I always hear a clunk or bang (brake assist?) from the front end. Is this normal? The car does brake smoothly if I press the pedal slowly.
Old Nov 21, 2010 | 10:21 AM
JFNash's Avatar
JFNash
Yes it's normal (at least for me, I got used to all kinds of weird brake noises).
Want a new one? Pull down the driver's window and slowly drive backward (or forward it doesn't matter) while slowly depressing the brake pedal. Enjoy the symphony.
You should also listen to the brake actuator noise. It's a lot more fun.
Grrrrrrrrrrrrrrrrrr!
Old Nov 21, 2010 | 01:21 PM
rominl's Avatar
rominl
exclusive matchup
yup, the brakes senses your pressure and apply brakes differently for you
Old Nov 23, 2010 | 01:58 PM
CJITTY's Avatar
CJITTY
well, my brakes were actin really touchy, especially front left wheel..then my caliper failed and basically threw abs/vsc codes and lexus fixed it, under warranty. bleeder valve got all messed up somehow..def get it checked out..lexus had to come pick mine up via flatbed
Old Nov 23, 2010 | 06:19 PM
I8ABMR's Avatar
I8ABMR
Funny, I just picked up an 07 and feel like the brakes dont bite. Its as if they were designed to stop as smoothly as possible
Old Dec 4, 2010 | 10:22 PM
blackz405's Avatar
blackz405
Problem solved. I replaced the original factory pads (with 131,700 miles) with Autozone DLG Ceramic pads today. The car now brakes normally.
Jonny1982
Jan 30, 2019 08:33 AM
daredeil95
Sep 11, 2018 08:36 PM
jimxms2
Maintenance
Nov 4, 2012 08:32 PM
Helmar
Aug 24, 2012 07:44 AM
Lexs400
Jul 8, 2005 02:29 PM
