Removing Spare to Save Gas
How much gas would I save if I remove the spare tire? I only drive locally anyway and it's been years and years since I had a flat requiring the spare.
how many times do you drive with anyone over 100lbs...thats like adding two more spare tires..sure, that makes no sense what i just wrote but taking the spare out is not a smooth move and doesn't make sense to me either..you arent racing civics at the track..keep the spare because odds are, you remove it, you'll need it soon after..not worth it. I'm sure the body weight ratio factors in the spare tire for overall performance in handling too when the car was designed
The cost of not having a spare tire available when you have a flat tire exceeds the benefit of marginally saving gas, if any, by removing the spare.
Try another trick: make sure the rpm doesn't go higher than 2000. I do that and a full tank gives me 320 - 360 city miles (95 octane gas, 5W30 fully synthetic oil. If I had 5W20, I would get even more miles out of my tank).
Ive been doing that and it DOES save gas. What about only running half a tank at a time?
Other weight saving tips are to remove all the doors (they are incredibly heavy), the hood and the trunk lid. Also, remove any unused seats as they are also heavy.
However you should replace the doors and trunk lid when there's a chance of rain.
......you should look in to getting a donut as a spare
Nope, won't work. I've carried jelly, chocolate frosted and Boston creme in the trunk, but I ended up eating them long before I got a flat.
