JIC Magic Coilovers
Old Jun 4, 2009 | 01:27 PM
cheers's Avatar
cheers
Default JIC Magic Coilovers
Does anyone on this forum have them on their LS and can you comment on them please???
Old Jun 4, 2009 | 03:41 PM
rominl's Avatar
rominl
exclusive matchup
platinum vip ls460 is on it, very low for sure
Old Jun 4, 2009 | 09:34 PM
clay7160's Avatar
clay7160
i have a set on my living room floor..waiting for wheels to come in before putting them on...very nice looking...thats all i can say so far
Old Jun 8, 2009 | 04:10 AM
pmvipjohn's Avatar
pmvipjohn
Default Ls460 jic
For your info. I drive 2007 LS460 JobDesign with fully loaded feature vip shows cars of 2007-2010. I have JIC Magic Coil-over with Platinum VIP. Cup KIT Air Suspension. They both perform outstanding performance an reliable suspension. Check out www.PMVIP.NET & www.PLATINUMVIPMOTORS.COM for more info:
1. Our Cup Kit will fit any coil-over as long as we have the shaft o.d. measurement spec.
if we do not have that measurement, than we may have to R&D that specific coil-over suspension unit to aqquired the right measurement to that coil-over application unit to fit the Platinum Cup Kits.
2. There are no generic components products that you can find to raise your vehicle with bodykit from damaging from going off the curb an bumbs or driveway. Our systems are sold complete & ready to install, i.e. compressor, tank (sold separately), quick release fittings, lines, and switches, gauges mechanical.
3. Others components, electronic items are sold separately i.e. digital gauges.
4. Inflation time is 5-10 second from ground to full height. Full height is max. at your specific coil-over application. They may vary depending on the coil-over setup if air bags is converted to our Platinum Cup Kit setup system was installed on your vehicle is inflated 3-5 sec. faster.
5. Adjustment of the air suspension cup kit heights to your decision. As I mention there are no expansion with our cups and when air is injected, as they respond instantly.
6. Full height to the coil-overs manufacture max height application. i.e. if you were to jack up your vehicle 2" until the tire is off the ground, thats max height. then 2" is all you'll get with JIC, we've attained a full 3.5" from the cup kits.
7. You can drive with 10% air in the system changing the spring rate. Keep in mind that the cups adds spring rate to the spring firming the ride instantly. The system should not leak at all and is fully lifetime warranty. Leaving air in the system will not harm the cup kits because there are no rubber involve like airbags setup suspension, so theres no rubber means no expansion of anything, thats our solid state cup kits system.
8. Instruction will be included and is a cut dry set-up. There no selonoids setup, and 1/4 airhose to all four cup kits plug and play basically with our quick connect fittings manual air valves means the control is at your fingertip, and trouble free.
9. The cup kits system is sold complete set of 4 cupkits prices ranges from $3200.00 - $4800.00.
is150
Nov 29, 2016 05:04 AM
is150
May 19, 2014 05:55 AM
phenomeno
Jun 17, 2012 09:48 PM
Platinum-VIP
Club Lexus Vendor Marketplace
18
Oct 31, 2010 09:40 PM
PlatinumIS
Suspension and Brakes
May 31, 2010 02:33 PM
