transmission output shaft seal leaking
Old May 27, 2026 | 10:03 AM
ni2xx's Avatar
ni2xx
Default transmission output shaft seal leaking
While replacing the transmission mount on my 2010 LS460 with 204k miles, I noticed a slight oil leak at the transmission output. It might be caused by a bad mount. At high mileage, engine/transmission mounts definitely need to be replaced.I looked it up and the seal is quite inexpensive. May I konw if anyone has replaced it before? Is this something that can be done as a DIY job? Thanks
Old May 27, 2026 | 01:19 PM
BB9's Avatar
BB9
This is not a leak. Leak is when you see oil droplets on the driveway. This is rather slight wetting. Don't bother, just keep your eye on it. If it took your tranny 200 000 miles to develop slight wetting, you probably have another 200 000 miles to go before it actually starts leaking and will require some action. LOL.
Old May 27, 2026 | 04:38 PM
Clean it off and check to see if it has drops forming after a short drive, it may just be normal seal wetting/seep. If it is dripping or the area gets wet again after a very short drive then you may want to replace it
Replacement is easy, remove the driveshaft and old seal then drive a new one in
Old May 28, 2026 | 07:22 PM
Lares733's Avatar
Lares733
Looks same as my underwear. No big deal.
Pattersom
Mar 16, 2025 07:17 AM
LWB460
Jun 14, 2024 01:35 PM
usedname
Apr 27, 2022 08:06 AM
lysis250
Sep 23, 2016 12:52 PM
roshanfiro
Apr 1, 2016 11:22 PM
