Temp
Old Jan 26, 2026 | 04:56 PM
Louslex's Avatar
Louslex
2nd gear
Default Temp
I have a 08 ls 460 with temp issue,the gauge works in normal range when at idle so does heat ,as you drive temp goes to cold and heat gets cool has any had this issue .coolant level is full.
Old Jan 26, 2026 | 05:22 PM
Anfanger's Avatar
Anfanger
You might have an air pocket in your cooling system.
Old Jan 26, 2026 | 05:43 PM
dlbuckls10's Avatar
dlbuckls10
Probably a thermostat issue.
Old Jan 27, 2026 | 04:47 PM
ArmyofOne's Avatar
ArmyofOne
Dysfunctional Veteran
Veteran: Army
Your thermostat is stuck open.
Solanus
May 29, 2023 03:57 PM
fabchef
Dec 15, 2022 10:08 AM
SC3coupe
GX - 1st Gen (2003-2009)
Nov 11, 2015 02:31 PM
mbaker7
Dec 30, 2012 04:21 AM
