Odometer showing negative value in techstream
Old Apr 29, 2025 | 02:09 AM
Trey616's Avatar
Trey616
Default Odometer showing negative value in techstream
checked my 2009 LS460 odometer on techstream. its not showing the odometer reading on the car homepage. But even under combination meter ecu its still showing -1 value under the odometer history readings. What could be the issue with these readings?
Old Apr 29, 2025 | 07:12 AM
Gerf's Avatar
Gerf
I think you will only see info there if you have a problem, doesn't it show you mileage on the system select page?
Old Apr 29, 2025 | 07:51 AM
Trey616's Avatar
Trey616
usually vin number and odometer reading should show in the system select page but it's not showing for my vehicle
Old Jul 23, 2025 | 11:30 AM
doriansanders's Avatar
doriansanders
1st Gear
Im having the same issue with my 2007, i think i have odometer rollback. Have you found a solution?
Slowexus
May 3, 2022 05:58 AM
Redeemed07
Feb 8, 2018 09:39 AM
Redeemed07
Feb 7, 2018 06:37 PM
Jasoneo5
Feb 13, 2012 12:59 PM
