New member
you picked a hell of a car for a first Lexus. As these cars age, especially the 07/08 models, they become absudrly expensive to maintain and repair, unless you do everything yourself, and even then, its not for the faint of heart. My car has 145,000 miles and it has had the following since 2018 (when i purchased it w/83,000 miles):
If i had a shop to all but the ZLZ interior stuff the total was going to be: $34,420, or $4,917/yr.
Since i DIY'd all except the Tires, interior, brake actuator and alignments, the overally cost of ownership looks more like this:
Bear in mind these #'s dont even include the ZLZ campaign, modifcations, fuel, air filters, oil changes, transmission services, rear differential fluid, brake fluid services, or coolant system services. It's $1,836/yr for me just to keep my car on the road.
- Brake actuator- $4,200
- Brake pads & rotors x4 corners- $985
- Upper & lower control arms/ball joints (twice)- $3,250 each time
- Tie rod ends- $450 (with alignment)
- Sway bar links- $400
- Sway bar bushings- $280
- all new door panels, dash, center console box, glove box door and B pillar interior trim replaced under the ZLZ campaign for sticky interior- $12,780 (warranty)
- oil pan replacement (was dented when I bought it and began to leak from the gasket)- $1,250
- oil filter housing o-rings leak- $750
- radiator- $1,100
- 2 MAF sensors- $1,400
- 2 O2 sensors- $685
- All new stereo (because the factory nav sucked and eventually stopped working entirely)- $3,500
- 4 struts and mounts-$2,760
- Engine mounts- $4,400
- 2 wheel bearings- $760
- Waterpump (was leaking)- $850
- 2 sets of tires (maintenance, but still expensive)- $2,800
- Blower motor-$1,350
- Brake pads & rotors x4 corners- $475
- Upper & lower control arms/ball joints (twice)- $600 each time
- Tie rod ends- $175 (with alignment)
- Sway bar links- $50
- Sway bar bushings- $25
- oil pan replacement (was dented when I bought it and began to leak from the gasket)- $85
- oil filter housing o-rings leak- $5
- radiator- $175
- 2 MAF sensors- $350
- 2 O2 sensors- $300
- All new stereo (because the factory nav sucked and eventually stopped working entirely)- $1,500
- 4 struts and mounts-$675
- Engine mounts- $250
- 2 wheel bearings- $240
- Waterpump (was leaking)- $185
- Blower motor-$165
The other things I have taken care of myself, but luckily, just the most expensive items were new tires, brakes, and rotors. Everything else has been quite minor. I work from home which means I probably only put 500 miles a month on the vehicle it at this point. I know I will want to sell it in a few years and look at a well-maintained 2016/17 or even an LS500 (we shall see).
My 2007 has 157k miles on it right now. The previous owner had taken care of most of the items you listed via Lexus or an independent Lexus/Toyota shop. I even called that shop, and they said anything needed, no matter how big or small, was taken care of or done preventively. I think I have been lucky so far with a good ownership history.
- radiator- $1,100
- radiator- $175
- Blower motor-$165
https://majesticsolutions.com/produc...ht-clear-coat/
So I pulled the label off the can I used since I see it's out of stock. This is the actual manufacturer. Great stuff.
https://www.ebay.com/itm/182417480444
ArmyOfOne, I was not surprised by your first list of repair costs, until I scrolled down to the second one, of your own actual O.T.D. (out the door i.e. everything incl tax) costs with them! I can't fail to be impressed by your scrupulous record keeping. If I were say, buying a used car from you I'd feel confident I was getting one that had been well cared for.
You'd think the first owner of a new car that cost $70,000 or more, would be savvy enough to maintain it appropriately, (and the Lexus site is a great help for figuring out what parts got changed and when) but naturally you can never count on this.
AsianGirl007
Oct 12, 2006 09:59 PM
AsianGirl007
Hybrid Technology
89
May 1, 2006 04:19 AM
