2011 LS beeping every 30 seconds
I cant figure out why. It does it while parked in my garage. Cant hear it that well while inside the car. I have checked all the doors are closed. Almost like the reminder beep when you leave car running and walk away.
It just started today. Was not doing it before today. And car had not been started or driven for about a week.
Although with the beep. I did start the car and let it run a minute. But no change in the beep.
2011 LS sport
Thanks for any help
2011 LS sport
Thanks for any help
2011 LS sport
Thanks for any help
2011 LS sport
Thanks for any help
I would have thought that there would be information on your screen for a warning beep, if not 2 things to try : a new battery in your smart key, also your 12v battery will probably be below a threshold, i would disconnect the battery and with a trickle charger give it 48 hours also by disconnecting the 12v battery it may reset whatever the problem was.
good luck
