LS460 persistent low beam issue
Old Mar 10, 2024 | 03:52 AM
TheJapManR's Avatar
TheJapManR
10th Gear
Default LS460 persistent low beam issue
I have a persistent issue with my right side low beam not working, has been like that since the day I bought my LS460 LWB
bought a new bulb changed it no light.
checked the engine compartment fuse box tested both fuses for power and
location 9,11 15Amp low beams fuses have power
saw someone say the ballast wouldn’t be an issue
ordered a Toyota Lexus Genuine Fuse Relay Engine Room Junction Block
LS460 OEM 82720-50081
from Japan. (Packaging was cool seeing Japanese newspapers)
replaced it today and same issue is still there but I’m going to say ballast but going to see about getting bulbs before I decide to pull my front bumper and removing the headlights and cleaning up the fog lights
Old Mar 10, 2024 | 10:00 AM
miket000's Avatar
miket000
I've had the ballasts be picky about bulbs. If you didn't install an oem bulb I would start there. Some of the aftermarket bulbs I had would illuminate for 20 minutes or so then turn off.
Old Mar 11, 2024 | 05:06 AM
TheJapManR's Avatar
TheJapManR
10th Gear
Thats a good start, what oem part number will work? idk if $150 bulbs would be worth it.
Old Mar 11, 2024 | 12:03 PM
miket000's Avatar
miket000
This is an easy site to follow to get part numbers. https://www.lexuspartsnow.com/
90981-20013
There are many revisions.
https://parts.belllexusnorthscottsda...981-20013.html
If you search on here there are some people that have posted which aftermarket brands worked for them.
Here are 2. https://www.clublexus.com/forums/ls-4th-gen-2007-2017/1013134-headlight-bulb-replacement-recommendations.html
https://www.clublexus.com/forums/ls-4th-gen-2007-2017/1014570-need-advice-on-replacement-lamps-for-low-beam-and-high-beam-2012-ls460.html
1Putt
Feb 19, 2024 10:43 PM
Mastiffman
Dec 15, 2023 08:05 PM
Gerf
Nov 4, 2022 06:00 PM
Moore007
May 14, 2019 07:21 PM
annparrish
Oct 8, 2018 07:28 AM
