XM Data
Old Feb 16, 2024 | 01:16 PM
Anfanger's Avatar
Anfanger
Default XM Data
I got my hands on an used head unit off LS600 for a small project I got. When I connected it to my car, it had XM stocks and weather working while it is unavailable on my unit. My understanding is that there is a separate XM module somewhere in the car. In my case, the XM unit is the same unit. However, one head unit gets XM data and displays the other one does not. How is it possible?
I manually going through the hard drives but I can't find anything other than LS600 hard has more data on it and it is a SATA drive.
Old Feb 16, 2024 | 05:11 PM
jmcraney's Avatar
jmcraney
I think you have a SiriusXM subscription issue.
Old Feb 16, 2024 | 05:31 PM
Anfanger's Avatar
Anfanger
I don't have a subscription, that is the point. I found, some indirect reference, that it uses radio HD network instead of XM network to function.
Old Feb 16, 2024 | 06:03 PM
jmcraney's Avatar
jmcraney
I think HDTraffic replaced XMTraffic beginning ‘13 or ‘14. HD does not require a subscription. Not sure but I don’t believe HD has stock quotes. As far as I know all SiriusXM data requires a subscription.
Old Feb 16, 2024 | 08:25 PM
Anfanger's Avatar
Anfanger
I agree with you, but I was able to pull Apple, NVIDIA stocks. Also, the weather app seemed to work as well.
Old Feb 17, 2024 | 09:24 AM
jmcraney's Avatar
jmcraney
One might conclude that the unit that receives SiriusXM data has some subscription time remaining, likely from the previous owner. Subscriptions are often purchased for 1 year in advance. I think that if you contact SiriusXM, with the unit's serial number, they will be able to tell you how much time is left on the subscription.
Old Feb 17, 2024 | 11:11 AM
Anfanger's Avatar
Anfanger
I read that Channel 0 should show the radio ID that I can run against the XM database. I will check the channel next time I will power up the unit.
waijai
Jan 5, 2012 05:07 PM
xrayman
IS F (2008-2014)
Nov 16, 2008 08:27 AM
snackyx
Oct 31, 2007 05:35 PM
TwentyTen
Dec 25, 2005 08:40 PM
