AC Recharge Port Location
Old Jul 12, 2023 | 12:36 PM
DJWLDW's Avatar
DJWLDW
Default AC Recharge Port Location
Want to refresh my 2010 LS460L AC and not sure of the location of the low pressure recharge port?
Dennis
Old Jul 12, 2023 | 12:52 PM
Gerf's Avatar
Gerf
High and low will be under the side engine covers somewhere, I've had my covers off a few times but I don't recall exactly where they are.
Old Jul 12, 2023 | 01:17 PM
Boykie's Avatar
Boykie
This is a good one. Two charge ports under driver side long plastic cover, plus one charge port in the condenser area.
Old Jul 15, 2023 | 10:01 AM
DJWLDW's Avatar
DJWLDW
Ok both ports are on the driver side under the small plastic cover. Both ports have caps marked with a H (high) and L (low) so they are easily identifiable as to which one you want to use. The L or low side is the correct one to use to refresh your AC system. The cold air coming out the dash vents now shows 38.4 degrees. I was a little low and now we are good to go.
Dennis
eevegas
May 24, 2021 07:13 PM
gebo
Maintenance
Jun 23, 2015 03:46 PM
cleethree
Aug 2, 2010 03:44 PM
TRDmike
Apr 2, 2010 02:59 AM
isiginamo
Apr 21, 2008 05:12 PM
