Where can I buy factory LS460L strut assemblies?
Old 03-11-23, 06:41 AM
Reparation
10th Gear
Reparation's Avatar
Almost got done but had the left rear swaybar end link nut seize. I've ordered new ones and I'll just cut this one off. But the job is not bad at all.
Old 03-11-23, 01:27 PM
Anfanger
Anfanger's Avatar
Do you know if you have the suspension ECU disconnected?
Reparation (03-11-23)
Old 03-11-23, 01:32 PM
Reparation
10th Gear
Reparation's Avatar
I'm not sure. It was already sitting on these Maxpeedrod coil overs when I bought the car. There is no lights of any kind though. Besides the one telling me to replace the front cabin air filter. Should it be plugged in?
Old 03-11-23, 01:55 PM
Anfanger
Anfanger's Avatar
My understanding is that it should be disconnected when switching to coils to prevent the air compressor from coming up. Disconnecting the suspension ECU should not set any error codes. I am going to disconnect mine tomorrow because I just switched to OEM coils as well.
Old 03-11-23, 02:41 PM
Reparation
10th Gear
Reparation's Avatar
Where is it located? I can check also. I have access to AllData.
Old 03-11-23, 02:47 PM
Anfanger
Anfanger's Avatar
It is mounted on the right side next to the glove box.
Old 03-11-23, 02:50 PM
Anfanger
Anfanger's Avatar
Old 03-11-23, 04:27 PM
Reparation
10th Gear
Reparation's Avatar
Old 03-11-23, 06:16 PM
Reparation
10th Gear
Reparation's Avatar
Oh my God, I love it. Thank you Anfanger and everyone else for insight. The car rides amazing and quiet on the inside. I'm sure better grade tires will help also.
w84me
ES - 5th Gen (2007-2012)
82
04-16-24 01:35 PM
jdanielca
07-02-20 06:02 AM
Manueljr91
07-16-19 07:08 AM
98SBF
08-12-12 10:34 AM
Quick Reply: Where can I buy factory LS460L strut assemblies?
