Help!
Hello,
When was the last time a timing belt was replaced?
Those codes indicate an issue with the timing in your engine, like if the belt were to slip or the Crankshaft sensor were to fail. Start by looking at the Engine Live Data, check that there RPMs are present when the engine is spinning, if the readout stays flat at 0, you may have issues with the crank sensor or its wiring. The sensor is pretty easy to check - hover it over something magnetic while checking the voltage across it, you should get some numbers, if not, the sensor is likely toast and needs to be replaced.
Hope this helps and best of luck!
