I recently installed a pioneer CarPlay radio into my non nav non ML 03’ 430.
-I noticed a crackling noise in the speakers and noticed the surrounds are completely tore off the cones when I did the door lock fix. So it needs door speakers. Are there any direct plug and play ones? I can’t find the ohm rating on the stock ones.
-I also can’t turn the volume up very high as I’m guessing it’s overloading the factory amp? I can get it to a normal volume but every once in a while there’s a song you want to crank up.
- The steering wheel controls don’t work with the pac PAC RP4.2-TY11 install kit I installed. Is there an adapter I could use just for this?
I searched for about an hr and couldn’t find the answers. Sorry if it’s been discussed before.
BigBoomer
close
- Join DateMar 2018
- LocationESSEX, UK
iTrader Positive Feedback0
iTrader Feedback Score(0)
Liked:391 Times in 317 Posts
You can replace the foams on the speakers with stick on ones.
Damaged speakers will distort like **** when you crank the volume.
Without the surrounds you will also destroy the speakers.
I’m fine with replacing them if there’s a direct (ish) bolt in. But it won’t matter if I can’t turn the volume up on the radio.
