2002 ls430 sulfur smell from hard acceleration
Old Sep 23, 2022 | 05:21 PM
Smw's Avatar
Smw
Default 2002 ls430 sulfur smell from hard acceleration
Hi folks
Need help. My 2002 ls430 with 126k is giving a very bad sulfur or rotten smell only when accelerating hard. It also happens when there are 5 passengers and ac is in and getting on freeway. I have no codes and zero drivability issues.
I have changed both o2 upstream sensors from denso, Spark plugs, air filter. No oil leaks. I only put premium fuel from costco. Took it to muffler place guy said try change gasoline from costco to chevron or 76. However I'm having a hard time accepting that costco gasoline is the culprit since thousands of people fill up there including me when I had a 2007 lexus gs350 9 months ago and for a whole year I only filled up costco and never had this issue. If anyone had this issue and resolved it please share you experience. Thnx
Old Sep 24, 2022 | 04:32 PM
pmesfun's Avatar
pmesfun
What octane do you run?
Old Sep 24, 2022 | 05:05 PM
Smw's Avatar
Smw
I always put the highest octane 91
Old Sep 24, 2022 | 05:08 PM
k7q's Avatar
k7q
Sounds like your catalytic converter is going out.
Old Sep 25, 2022 | 11:14 AM
StanVanDam's Avatar
StanVanDam
https://www.clublexus.com/forums/ls-...l#post10370558
Old May 23, 2023 | 06:48 PM
AngoLS430's Avatar
AngoLS430
Did you ever find a solution? My friend and I are having the same issue with our 2001 & 2004 LS430s!
Old May 24, 2023 | 01:26 AM
BigBoomer's Avatar
BigBoomer
https://www.hbautoandac.com/our-blog...ke-rotten-eggs
If it is only happening under heavy engine loads, then I would suspect the fuel pressure being too high but could also be either of the other 2 possibilities.
MileHigh
Oct 4, 2023 09:29 PM
lexusdog
Sep 1, 2017 05:19 PM
elid786
Jul 26, 2016 06:05 AM
peggypwr1
Jun 13, 2015 02:50 PM
BadBoy
Maintenance
Feb 17, 2006 08:07 AM
