Please help diagnose. Major issues after timing belt service
Several months ago I had my timing belt changed. to include radiator, water pump and PCV, and all sparkplugs
A day after I picked up my car from the mechanic I got a VSC/Track Off/CEL with "System too lean Bank 1/Bank2" code.
I went on vacatio nand didn't drive my car for a month but when I came back I got an "Oil Level too low"
I refilled my oil and notice puddles when ever I park. Oil color is a pink shade of orange and leaking from the front. I found a youtube video to check PCV pressure and I still have good pressure coming from the oil dipstick hole.
(https://www.youtube.com/watch?v=l3ppNvofPHI)
So what is going on. What is causing VSC error, system too lean, and my car hemroging oil? Is this a critical issue or can I just keep dumping oil in my car?
Should I set my car on fire?
I'm only guessing but it sounds like the mechanic that did the work botched a bunch of things. Did the car lose or burn oil before the work was done?
Did a shop do the work? If so, there should be a warrantee... get the car towed back to them to check if so.
What was the oil level before you added? Did you check or just dumped in more oil.
Do you have an oil leak or coolant leak. Or both? Coolant is pink assuming Toyota coolant was used.
Need a scan tool to read the codes.
2. Dont know about coolant. I'll check coolant level too.
3. Codes are P0171 and P014
[size=13px][/size]
Yup, a shop did the work late October. I brought my own parts and they installed them.
So they probably won't honor any parts or labor if you provided the parts. What brand of parts did you go with? It sounds like you're leaking coolant so either the waterpump wasn't installed correctly or you used something other than Aisin. Your car shouldn't be leaking oil from any of the work that you described.
You either need to take it back and see what they can do to make it right (compare the mileage when it left the shop to the current mileage to show you haven't driven it) or you need to try and determine where the leaks are coming from. Maybe the radiator hoses are loose? As far as your codes, you'll need to research each code and try the different suggestions. Might be a loose pin if they were tugging on the COPs because they can be snug sometimes.
COP Coil On Plug... real easy to pull the pins out of the connector if you tug too hard (or at all). PCV oil leak would easily be visible due to location.
As far as the Aisin kit, hopefully you got it from a good vendor... lots of fake parts out there. Anything from Amazon might as well be considered a fake part at this point. Only order from a Lexus dealer or someplace like Rock Auto...
Get the car up to temperature and then park it over a fresh sheet of cardboard to see how much leakage you actually have...
Jabberwock (01-21-22)
MikeyF23
04-18-20 05:45 PM
Ravencrave
53
06-06-16 10:00 AM
