Help! Radiator Exploded...
Old Mar 3, 2021 | 10:28 AM
Wlpls430's Avatar
Wlpls430
Default Help! Radiator Exploded...
It looks to me like I need a new radiator (and might as well do the timing belt), but based off of the pictures, do you think it's much more severe? Thanks!
Sorry for the low res pics, CL won't let me upload HEIC images.
Old Mar 3, 2021 | 10:39 AM
TominPT's Avatar
TominPT
I'd replace the hoses and the radiator cap while you are at it too.
Old Mar 3, 2021 | 10:46 AM
bradland's Avatar
bradland
This is actually fairly common, although yours does look fairly extreme.
By chance have you recently topped off the fluid in the reservoir? The reservoir is an overflow tank which, when cool, should be only about 1/3 full. This gives expanded hot coolant a place to go when the engine warms up. If the reservoir is full the fluid is forced out through the reservoir cap (which is just a snap-fit) and the tiny hoses attached to the reservoir. Once the fluid escapes the serpentine belt movement sprays it everywhere making it look much worse than it actually is.
Notice how the top of the reservoir is at the center of the mess.
I'd clean up the expelled coolant, check the level is correct, then drive it carefully (locally) and see what happens.
Old Mar 3, 2021 | 11:49 AM
Aus430's Avatar
Aus430
Is there fluid in the radiator under the cap?
Old Mar 3, 2021 | 07:43 PM
CSA's Avatar
CSA
Rehab the entire cooling system. It''s probably due. In my experience with Toyotas, once you get north of 140K or so, it's time for a new radiator, hoses, T-stat, etc. If a timing belt is due, might as well address that along with the water pump and the serpentine belt.
CarNerd400
Mar 3, 2021 12:21 PM
dukiedave
GX - 1st Gen (2003-2009)
May 11, 2020 09:30 AM
rwdanthony
Dec 24, 2008 10:12 PM
pmpdaddyt
Nov 1, 2008 04:26 PM
VotT
Nov 9, 2007 08:40 PM
