Help!!! Cannot get into my car even with the physical key
Help!!! I cannot get into my car, even if I put the mechanical key in and turn clockwise, notthing happen. What could be wrong here?
This happened after I tried the trick of rolling up the window using the mechanical key (put in the key hole and turn/hold clockwise). The trunk button still works and the trunk light is on so I think the battery is ok. Also the mechanical key should work anyway right?
Yes the mechanical key should unlock the doors regardless of what you have done. Try wiggling key in lock cylinder. Can you get into the trunk? Key fob battery dead? If so, perhaps slap a new battery in and attempt to unlock doors?
Now the lesson is learned: don't do this trick, but how do I disable it?
