Hidden Broken Braided Ground Wire
I have had that ground wire broken since I did my header install 2 years ago and my car shifts fine.
Does anyone know (exactly) why Toyota added a ground wire to the A650-E transmission?
Were Toyota engineers resolving something or a matter of production line workers run amok?
2001-2003 LS430 used Aisin A650-E 5-speed transmission, as did the 1998-2000 LS400, however LS400 did not use a transmission ground strap.
The 2004-2006 LS430 6-speed transmission is apparently more problematic...or at least the electronics repair shop whose name keeps coming up is able to trouble shoot it...but it remains unclear exactly WHAT component(s) replaced or software modifications.
Yamae?
Thanks
If integrity of a ground point is compromised by corrosion and/or oxidation, or separated ground then electronic circuits are affected.
Cold solder joints on ECU have not come up on the LS400 side (mostly capacitors).
Perhaps the LS400's ECU location inside the vehicle vs LS43O's ECU under hood has anything to do with failing solder joints.
Whether or not the LS430 ECU is cooled by vents, it is still operating in an environment that is significantly higher than the cabin.
The temperature cycling, never mind the heat soak on shutdown, is considerable...and this expands and contracts the circuit board.
Returning to the unanswered question concerning the grounding strap...
Toyota made a conscious choice to add an extra "grounding strap" between transmission and chassis (vs engine only grounding of LS400)
Does anyone know what engineering input prompted Toyota to increase production costs by incorporating this additional component??
Thank you.
If both, does SIA work its magic on 1998-2000 LS400 ECU with same five speed transmission??
My read is the 2004-2006 LS430 with sealed 6-speed transmissions were most affected...
Thanks.
Thanks.
Issues can arise from any of the following- incorrect fluid, incorrect fluid level, old fuel dampers, dirty throttle body, ECU glitches, etc...
Misdiagnosing any or all of the above under the “Transmission issue” umbrella makes it seem like a very common problem but in all actuality the Transmission is not the real issue.
Yes SIA Electronics will service a 400 ECU. Their website is not hard to find- https://siaelec.com/product-category...repair-return/
First, do not wish to advertise a company that cannot provide a straight answer as to WHAT they actually repair/ replace/ program on 2004-2006 LS430 ECU...
When we take our stereo for repair, the shop advises the faulty component and labor costs before obtaining approval from customer to effect repairs....
On that topic, I contacted said vendor as to actual service performed and was given a B.S. answer....and based on that interchange DO NOT recommend them.
The reason I am parsing out the 2001-2003 from 2004-2006 transmissions here is because the former is less problematic than the latter and redirect attention to the grounding strap question
So we have an A650-E transmission used on 1998-2000 LS400, 2001-2003 LS430.
Can't seem to acquire an answer from.anyone to the question why Toyota added the transmission ground strap.
Seems like that info could make most of the argument a mute point.
This thread can be debunked easily go put a voltage stabilizer on your car and then tell me if it improves anything performance wise the answer is no. One little ground strap is not going to make or brake how the transmission shifts it is ludicrous to think a strand of copper could effect that.
Does anyone have information why Toyota added a transmission ground strap??
Thank you.
At least that what I have found working on the newest German stuff
