2005 Lexus LS430 front passenger-side power window goes down, but doesn't go up all the way after that, *occasionally*.
No amount of tweaking (using the driver side and passenger side power window controls, winding down and up all windows, pushing and pulling the affected window to maybe try and coax it back into operation, stopping the engine, restarting, then retrying, etc) works to bring up (or even significantly move) the front passenger-side window in this condition.
What does work is to turn off the engine, wait for about an hour, restart the car, and use the driver side control to wind up the window.
This can be a security problem if it happens somewhere (or if it rains) where you need to park and don't have the time to get it to work properly.
What should I look at to fix this occasional window operation anomaly?
It's time for a new window motor or even better the whole regulator assembly. I fought my driver's side front window for a long time and I'm glad I finally replaced it. My window would roll down without problem but going up it would get stuck half way and you could either wait a minute for it to cool or assist the motor by pulling the window up yourself.
These window motors have a thermal resistor as it gets hotter the resistance increases and the motor loses power, that's why if you get it time to cool off it works. I believe this is a safety feature either for the motor or for objects caught between the window and frame (fingers) but the resistor does wear out it seems.
aypues
close
- Join DateFeb 2008
- LocationCA
iTrader Positive Feedback0
iTrader Feedback Score(0)
Liked:70 Times in 51 Posts
I recently replaced all three components of the power window: the motor, the regulator, and the run. It was expensive but it works perfectly now.
UL’s have a different run unfortunately that requires way more labor to install.
Quote:
If I take the door apart, I probably won't be able to put it back together the same way it was or without damaging it 😂Originally Posted by jharris400
If only I could be an apprentice somewhere (even work for free) and try this out on somebody else's car to learn how to do it right...
Is this something an average technician in an automotive electrical shop (stereo, dashcam, etc installers) can competently do if I supply the parts from Amazon?
I'd hate to take it to a dealer and ask how much this would cost. 😱
Bocatrip
close
- Join DateMay 2006
Liked:304 Times in 256 Posts
A Toyota dealership would be cheaper, but owning an old car likes ours requires a reputable Independent shop or repairs can become costly. I'd ask around. Unfortunately, so many people have leased cars that are under warranty and it's getting harder to find good Independent shops. Good luck. Originally Posted by Natey2
If I take the door apart, I probably won't be able to put it back together the same way it was or without damaging it 😂If only I could be an apprentice somewhere (even work for free) and try this out on somebody else's car to learn how to do it right...
Now my rear driver side door lock actuator has quit working. All the other door locks respond to the electronic lock/unlock signal.
Found this amusing but informative video ( ) on how to fix it.
I am going to find/pay someone to fix these problems. There's no way I can pull this off myself.
