ACIS system testing bidirectional techstream
Old Sep 23, 2019 | 06:32 AM
jharris400's Avatar
jharris400
Default ACIS system testing bidirectional techstream
I believe my ACIS system isn't working, my car seems to be lacking low end power. I have tried activating it with my techstream with the "intake vsv" command and my launch diagun iv, neither tool showed a movement in the actuator. I can move the actuator by hand and my CEL is not on these tests were done with the engine idling.
I know my engine has been messed with in the past by POs, when I bought it there was dried coolant everywhere and the radiator had been replaced. Upon further research I recently found out through lexus service records that the engine had been overheated and ran poorly with the suggestion that a headgasket was bad. I assume the owner took it to an indy guy and had the headgasket replaced where the guy also misplaced a few bolts that held down the wiring loom and heater pipes. I'm thinking that guy also neglected to install the ACIS hoses correctly but it's a job that will require $50 in gaskets to check so you can see why I'm reluctant to pull the manifold.
I'm going to see what I can do with an inspection camera to look everything over but I don't have a lot of hope. I am also going to try to manually activate the VSV being that the connector is easy to get to on the passenger side of the intake manifold.
Old Sep 23, 2019 | 08:28 AM
weldthedif's Avatar
weldthedif
what does ACIS stand for ?
Old Sep 23, 2019 | 08:35 AM
jharris400's Avatar
jharris400
Acoustic Control Induction System, similar to TVIS Toyota Variable Induction System.
Old Sep 23, 2019 | 10:33 AM
weldthedif's Avatar
weldthedif
very interesting, never heard of this before.
Old Sep 23, 2019 | 08:14 PM
jharris400's Avatar
jharris400
After doing some troubleshooting tonight I found the VSV or the sub harness going to it must be open, with a multimeter I get no resistance when checking from the connector on the side of the intake manifold. Using an inspection camera I verified that the VSV was connected, no hoses were loose and the connector looked good.
I also tested the functionality of the bidirectional control of the VSV. When controlling "intake vsv 1" I can activate and deactivate the VSV which I substituted with a test light for the test.
I have the ACIS valve closed by using a zip tie on the back of the intake manifold to hold it closed, this is purely a test until the parts I need arrive. Unfortunately this means I have to remove the intake manifold.
Old Sep 24, 2019 | 08:07 AM
weldthedif's Avatar
weldthedif
might as well get your injectors sonically cleaned while having the intake manifold open.
Old Sep 25, 2019 | 07:52 PM
jharris400's Avatar
jharris400
I figured this topic would be over the heads of this forum. Keeping the ACIS plate closed (as it would be if my VSV worked) has netted a MPG increase and more low end power. Before I would routinely see from 22 to 23 MPG now I'm seeing mid to high 24 MPG. Keep in mind the ACIS plate should only open above 4700rpm and 60% throttle, any other time the plate is closed forcing the air to take the longer runners in the intake manifold.
I bought an entire intake manifold with every part from the ACIS just incase I run into more than just the VSV, turns out that VSV is open as well. Seems like with age and heat these VSVs fail, mine isn't just a fluke.
Old Jul 25, 2022 | 06:43 AM
jharris400's Avatar
jharris400
I finally made myself remove the intake manifold and replace the VSV. Low rpm power is better definitely a noticable improvement. Cartunenz made a video about this a while back for those who care to watch.
Sandi_k
RX - 3rd Gen (2010-2015)
Mar 25, 2019 10:07 AM
NA2jz
IS - 1st Gen (2001-2005)
Aug 28, 2017 12:22 PM
Diegolazo5
Mar 2, 2015 06:52 AM
zaphod
Jul 10, 2009 03:53 AM
RA40
Maintenance
Sep 4, 2003 08:31 AM
