Air suspension problem
Old Aug 26, 2019 | 07:53 PM
Shinick's Avatar
Shinick
Default Air suspension problem
Just noticed last night that my car's front passenger side is sitting a bit low and after starting the car the height seems to go back to normal. The ride still feels smooth and there is no noise coming from the suspension. Could that be a sign of leaking air bag
Old Aug 26, 2019 | 08:19 PM
Shinick's Avatar
Shinick
By the way what does a completely failed air suspension strut look like? Does the upper part of the tire get in contact with the fender? Also, does the air suspension compressor engages when the car's engine is off?
Old Aug 27, 2019 | 05:16 AM
rkw77080's Avatar
rkw77080
No, the upper part of the tire will not come in contact with the fender when the air shock is completely deflated, and No, the compressor will not start with the ignition off. It's likely that you have a leaky air line connection. Please take a look at the excerpt from the factory repair manual below...
Old Aug 27, 2019 | 07:58 AM
Shinick's Avatar
Shinick
Thanks! I will check them. By the way, what is the best solution to repair a leaking air line connection? Or can I just live with it?
ReeM
Suspension and Brakes
Nov 22, 2016 07:10 PM
gcam77
GX - 1st Gen (2003-2009)
Feb 16, 2016 07:39 AM
LostS0ck
CL of Hawaii
Oct 23, 2012 02:45 AM
GSJDM430
May 10, 2009 11:50 AM
