Low Oil Warning
Old Mar 26, 2019 | 02:41 PM
anthony913's Avatar
anthony913
Default Low Oil Warning
Does the 2002 LS430 have a system that will tell you if your engine oil is low? Or is the only way to tell is to continually check the dipstick. Also, is there a low coolant warning that appears if too low or is this also a manual check?
Thanks
Old Mar 26, 2019 | 03:41 PM
BCT's Avatar
BCT
Have you look at the manual?
Old Mar 26, 2019 | 04:34 PM
anthony913's Avatar
anthony913
I just looked and it does have a warning for oil but not coolant.
Old Mar 26, 2019 | 06:10 PM
bradland's Avatar
bradland
if your car is low enough on coolant to the point where it becomes an issue the temp gauge will rise AKA warning...
Old Mar 26, 2019 | 07:18 PM
jayclapp's Avatar
jayclapp
I have 138,000 miles and have quit even bothering to check the oil level between 5,000 mile oil changes. Absolutely does not use oil! Have used Mobil 1 since owned for the last 118,000 miles.
Old Mar 27, 2019 | 01:05 PM
Gronemus's Avatar
Gronemus
There is a oil level sensor that a located right below the bank 1 sensor 1 oxygen sensor and connected to the same harness as the O2 sensor...
Aus430
Oct 10, 2018 08:37 PM
hermansen
May 18, 2018 11:34 AM
Ken167
Nov 29, 2017 12:48 PM
flyingjack
Jul 10, 2013 12:01 PM
