Plugs and coils for 05 LS
Old Mar 19, 2019 | 10:37 PM
RJM17's Avatar
RJM17
10th Gear
Default Plugs and coils for 05 LS
Hi folks,
Time to change plugs; wires and coils in my 05 LS. Any suggestions for suppliers other than OEM ? Thanks!
Old Mar 20, 2019 | 12:32 AM
bradland's Avatar
bradland
Plugs-
Denso SK20R11 or NGK IFR6A11
Coil-
Amazon Amazon
Old Mar 20, 2019 | 06:44 AM
Romanova's Avatar
Romanova
Don't try and save a buck and use aftermarket junk, you'll regret it in the end. I'm curious as to why you are going to replace the coils? Unless you have a specific failure, just do the plugs and be done with it.
Old Mar 20, 2019 | 12:21 PM
Johnhav430's Avatar
Johnhav430
Maybe OP has a $500 gift card he needs to use up?
Old Mar 20, 2019 | 02:51 PM
YODAONE's Avatar
YODAONE
Originally Posted by RJM17
Hi folks,
There are no (spark plug) "wires" in an LS430.
Unless you have trouble codes then replacing COP igniters should not be necessary...
As to spark plugs, OEM supplier NGK now offers a "Ruthenium" spark plug which offers significant advantages over the stock "Iridium".
See;
https://www.clublexus.com/forums/ls-1st-and-2nd-gen-1990-2000/904773-ngk-ruthenium-hx-spark-plugs.html
As you are experiencing challenges over removing the 10mm coil pack bolt, are you comfortable with changing spark plugs and have necessary tools, such as torque wrench (torque specs necessary) ?
Old Mar 20, 2019 | 05:53 PM
RJM17's Avatar
RJM17
10th Gear
I'm good to go, thanks!
Old Mar 21, 2019 | 10:56 AM
balanced6's Avatar
balanced6
OP, which plugs did you end up choosing and why?
halloo
Feb 3, 2022 08:07 PM
PlatES300
Jul 16, 2018 05:12 PM
2GSTony
Dec 12, 2014 11:46 AM
bkim
RX - 1st Gen (1999-2003)
14
May 21, 2014 01:15 PM
dry-fly
Sep 29, 2011 06:10 PM
