What other components do I need after coilovers?
Old Jan 31, 2019 | 11:45 PM
cookieend's Avatar
cookieend
Default What other components do I need after coilovers?
I’m getting coilovers soon on my 05 ls. Plan to go pretty low but not hot boi low. So my question is, will anything break or bend due the the height of the car? Like tie rods, control arms ect.. if so what’s a good after market brand for the item. And will I need any other component for an alignment? Thanks for the help.
Old Feb 1, 2019 | 11:22 AM
wellknown's Avatar
wellknown
https://www.shopfigs.com/v3/by-vehic.../cat-G3-LS-CAT - as far as i know as long as you're not going HotBoi low you should be fine -- Figs is the place to go for all things -- you can also find other brands like Megan etc. out there.
Old Feb 1, 2019 | 11:46 AM
05ls430518's Avatar
05ls430518
Yah tires wheel bearings, bushings, will experience extra wear you are changing the suspension geometry of the car that was engineered by Lexus.
Old Feb 4, 2019 | 11:55 AM
cookieend's Avatar
cookieend
so need replace everything is what you says? Toe arms, upper and lower control arms, traction arms as well with the rear?
Old Feb 4, 2019 | 11:59 AM
cookieend's Avatar
cookieend
thanks man this is for sure a go to site for even I go lower. I’ve been hearing so far is that everything hat is stock won’t have issues besides the toe due the the height of the car. ( and camber obviously will be present ) please correct me if I’m wrong, I don’t wanna f my car up
Old Feb 6, 2019 | 11:50 AM
kos's Avatar
kos
Having the adjustability of spherical / pillowball arms will make whoever does your alignment have less of a headache. The downside is the cost.
Old Feb 24, 2019 | 08:22 PM
cydalLS's Avatar
cydalLS
I read somewhere you may need rear extenders? I too am asking this questions for a proper drop
Joekgs
Jun 14, 2017 08:34 AM
PandaGS300
Suspension and Brakes
Nov 21, 2015 05:59 PM
keepit
May 31, 2015 09:21 AM
416tt
May 24, 2014 10:49 PM
Anferny
Oct 25, 2011 04:06 PM
