Help......damaged lug nut & stud
Old Nov 21, 2018 | 02:09 PM
  #31
ebxgsxr's Avatar
ebxgsxr
well, i finally bit the bullet. i ordered the lug ripper kit. found one on ebay for $200 shipped. this way, i know the wheel will not get damaged during removal.
since i "inherited" the car from my wife i have done everything except the timing belt service and replacing the converters. so i would rather take care of this myself.
i'm going to cross my fingers and hope i can just put a replacement stud in. otherwise, i'm going to have to have the spindles replaced along with the hub. but i won't know if that will work until everything is apart.
Old Nov 21, 2018 | 03:14 PM
  #32
ls430w140's Avatar
ls430w140
Ouch but will this kit actually help in your situation? If it’s possible, please show how it looks.
Old Nov 21, 2018 | 03:29 PM
  #33
Ellesse's Avatar
Ellesse
I'm in process of trying to get new wheels on and put spacers on all 4 corners.
I used this to get the studs in, for just one you could just do the washer method but damn this thing was useful!!
https://www.amazon.com/Lisle-22800-Wheel-Stud-Installer/dp/B000ETUD22
Old Nov 22, 2018 | 01:41 AM
  #34
Johnhav430's Avatar
Johnhav430
Originally Posted by ebxgsxr
well, there is a long story on why i'm dragging my feet.
a while ago, i was going to replace the rear pads & rotors, but couldn't get the caliper bolt off. brought it to a shop, and they said that it's probably going to break. got new bolts from lexus, but after talking to the guy at the shop, he said that if i ever have to remove the caliper again, i will probably not be able to get everything back together and that i would need a new spindle. so this bad stud will end up costing a lot more than just a replacement stud or even what a replacement hub would run me.
My understanding is the knuckle is aluminum....and the rear bolts are only 58 ft. lbs. (these I just do by feel) If they got it off and reinstalled, why would this be the last time the caliper could be removed.....
Old Nov 22, 2018 | 04:23 AM
  #35
ebxgsxr's Avatar
ebxgsxr
well, the caliper bolt was frozen. they called me and said if they continue it could break. but i have to replace the pads and rotors, so i had no choice. they said the bolt broke, but they were able to remove the remnants and "install" the new ones. but he said if i ever have to remove them again, that the spindle would probably have to be replaced. so i am just going by their word, since i have not had to remove anything, i just figured i would cross that bridge when i got to it.
once i get the tool in (i got the email saying it has been shipped) i will see if there is any truth to what i was told. but it is a shop that deals with our parts store on a regular basis, so i don't really see why he would lie to me. but you never know. lol.
Old Nov 22, 2018 | 04:30 AM
  #36
ebxgsxr's Avatar
ebxgsxr
yes, the tool that i purchased was actually made for this situation. i will document my experience with the tool. but i'll see if i can find the video i watched of it being used.
https://www.amazon.com/Lisle-22800-W.../dp/B000ETUD22
yeah, i figured if i can just install one stud without replacing the whole hub, i would need something like this or use washers. but i am the type that likes to have the correct tool for the job, lol. so i will probably be getting one too.
Old Nov 22, 2018 | 04:56 AM
  #37
ebxgsxr's Avatar
ebxgsxr
here is the video that shows how it is used.
ksan
Wheels, Tires & Brakes Forum
Feb 27, 2014 06:31 AM
OG Dada
Aug 14, 2012 04:33 PM
sleekbrian
Jun 23, 2011 04:22 PM
ApoK
Oct 12, 2008 05:43 AM
anthracitetarga
Jun 25, 2001 10:13 PM
