Tin Can Sounds
Old Jun 26, 2018 | 04:52 AM
RushNatU's Avatar
RushNatU
Default Tin Can Sounds
This is my third LS and the last one I had did the exact same thing. Its so annoying but could never figure out what it was. Maybe you guys can point me in the right direction. I will try to describe the circumstances of the noise.
I have 20” wheels on 35 series tires so road noise is louder as to be expected. When going over certain types of (hollow or raised?) concrete pavement, there is a “keys rattling in a tin can” buzzing noise that seems like its coming from the steering column or below the car. Its fairly faint and only happens when the resonance from the tires is just right and I am barely pushing on the gas.
Would really love to solve this “issue”. Lol.
Old Jun 26, 2018 | 05:49 AM
Johnhav430's Avatar
Johnhav430
Does this happen when you hit bumps, and when you apply the brakes lightly, for the first time? A metallic sound, as if you hit a piece of metal with a rubber mallet, just right?
If so, my indie told me to install the original shims that are missing from the car. He drove my car very carefully, then inspected it on the lift. He even tapped the top of my brake pads with a small hammer to duplicate the sound. I do have the shims but I have not replaced the brakes so I don't want to put them in until that time, so I live with it....this forum also states what my indie said on old threads...it's worth a shot.
If your shims are there, then obviously it wouldn't be the issue....
Old Jun 26, 2018 | 11:37 AM
RushNatU's Avatar
RushNatU
Yes all shims in place. The brakes dont make any noise. Its like keys jingling behind a closed door type of sound. My last LS did this too and was hoping someone has found a possible cause. I was thinking of taking the plastic off around steering column and drive around to see if I can locate it. But it could be below the car, not sure.
Old Jun 26, 2018 | 11:43 AM
rkw77080's Avatar
rkw77080
The aluminum heat shields under the chassis can create your tin-car rattling noise. There are several of these heat shields that are strategically placed between the exhaust system and the underside of the cabin. One or more of the mounting bolts/screws may be broken or loose.
Old Jun 26, 2018 | 12:34 PM
SlkySmooth's Avatar
SlkySmooth
I have the exact same sound. To me it seems to be coming from the passenger side. From what people were describing the sounds of their bad LCA caster bushings I was hoping the bushings I plan on replacing would help. Aluminum heat shield does sound like it'd make sense though
Old Jun 28, 2018 | 07:11 AM
aufenscuht's Avatar
aufenscuht
It could be an idler as well-I would check the heat shields first, for sure!
Old Jun 28, 2018 | 07:18 AM
RushNatU's Avatar
RushNatU
Thanks all. I will check heat shields first and report what i find.
EIO
Jun 18, 2011 10:48 AM
Billy305
Apr 7, 2010 07:04 PM
Danimal
Mar 9, 2008 03:25 AM
natedahms
Dec 22, 2007 10:08 AM
