I need help replacing this bulb
My right two bulbs went out it’s been about a couple months and I really need to replace them if you can send me a link for both bulbs if possible
hahahaha. Search online for the best price as I found my trunk mounted LEDs on ebay for reasonable prices but way more than a simple bulb.If its a pre 2004 MY stop light is 7443 use this site to confirm the other missing bulbs and pick them up at any Walmart or auto parts stores, even Amazon: http://www.philipsautolighting.com/b...2003&trim=NULL
Also - confirm if the 3rd brake light in the back parcel shelf is indeed working. Looks like brakes are on in the photo and no 3rd brake light, but can't tell for certain in photo. Easy fix - search this forum for how to slide the cover off to the side as you access it from the back seat.
Cheers,
hahahaha. Search online for the best price as I found my trunk mounted LEDs on ebay for reasonable prices but way more than a simple bulb.Arab, unfortunately you definitely have LEDs. Like Galco said, they're not as simple as replacing a bulb, and have to be replaced all together. You're going to have to pull the trunk lining away to gain enough access to replace the lights. There are a number of YouTube videos that show this, including a video I just watched which was for removing the amplifier for the stereo. You have to pull the trunk lining away in the same exact place to access the amp, so just watch the video and you'll see.
Actually I just found the video again...
Arab, an easy way to tell if your 3rd brake light does in fact work is to back your car up to a building with a window that's in line with your car. Sitting in your driver's seat, push the brake pedal and look at the reflection in the building's window using your rear view or a side view mirror to see.
I would gently peel back the trunk's fabric/liner, then find and loosen and remove, then fasten and secure the connector properly. It could simply be a bad connection.
