Question on removing camber bolt
Old Feb 28, 2018 | 08:26 PM
05ls430518's Avatar
05ls430518
Default Question on removing camber bolt
If i draw a line on both sides of the bolt thst goes onto the control arm and remove them, if I line my marks up will the alignment specs stil be how they were before I moved the bolts?
I am gonna remove them to install the 4 point chassis brace.
Old Mar 1, 2018 | 03:52 AM
rkw77080's Avatar
rkw77080
Your are correct. Making a mark for re-installation is the recommended procedure (see attached). However for your case, the chassis brace will increase the overall stiffness of your suspension system and alter/minimize how your front end settles. A wheel alignment is strongly recommended.
File Type: pdf
Old Mar 1, 2018 | 04:10 AM
Gronemus's Avatar
Gronemus
With all of the mods and money you are spending on the suspension for this car I would have thought that you would simply get an alignment when you're finished with the project...
Old Mar 1, 2018 | 04:24 AM
05ls430518's Avatar
05ls430518
I am deffinetly getting an alingment done no worries there, I have to travel 40 mins away one way to go to this race shop to get an alignment, so I dont want my car to be to out of wack if that makes any sense at all.
I dont know about you guys but were I live it is very hard to find someone who can do an alingment properly. Also no project is ever truly finished when it comes to cars haha
JKweezy
IS F (2008-2014)
15
Sep 29, 2017 07:50 AM
pilot2
RX - 1st Gen (1999-2003)
Sep 25, 2014 06:59 AM
seivonecsu
Oct 10, 2012 12:16 PM
RickJames1
Feb 21, 2010 08:58 PM
fireballs gs400
Maintenance
Aug 14, 2006 01:18 PM
