Antenna adapter problem
Old Jun 17, 2017 | 12:33 PM
NL5's Avatar
NL5
Default Antenna adapter problem
So, I got a Grom BT3 with the HD radio adapter. With the supplied antenna, I couldn't get reception worth a darn, so I bought the Metra adapters and a 17 foot extension cable. Hooked those up to the stock antenna, and split it to the Grom and the factory radio. Getting somewhat better reception, but not what it should be, and the stock radio is not getting the reception it was before. Not even close. What I have traced it down to I believe is the Metra adapter from the stock antenna. It's a two port connector that was plugged into the back of the stock tuner in the trunk. It has two leads going into it. However, the Metra adapter is only using one. I am pretty sure that it's using the wrong one. So, my question is, is their an adapter that uses both? Or, has anyone else come across this problem and found a fix? Any help is greatly appreciated. This is on an early 2001 ls430 with ML and nav.
Otherwise, the Grom is fantastic, and when I get reception, the HD radio sounds way better than regular FM.
Thanks!
Old Jun 22, 2017 | 10:51 AM
NL5's Avatar
NL5
Nobody else has run into this problem?
Old Jun 22, 2017 | 12:26 PM
Daspyda's Avatar
Daspyda
IIRC, the audio antennas are in the rear glass, and there are two.
Old Jun 30, 2017 | 07:23 PM
NL5's Avatar
NL5
So, after much trial and error, I think I got it figured out. I thought I would post my solution in case anyone having this problem in the future finds this thread.
I first tried removing the antenna adapter from the clip and temporarily installed it on the second lead from the antenna system. That worked better, but still wasn't what it was when stock. So, I ordered a second Metra adapter for the antenna side and took the lead I removed from the first adapter, and inserted it into the second slot of the new adapter. Then, I took a 2f/1m y adapter and combined the two antenna leads. Next, I took a 1f/2m y adapter and spilt them to the grom and the stock tuner. Now, I am getting great reception on the grom hd tuner, and the stock fm tuner. A lot of effort, just to get a good signal, but worth it in the end. Stereo sounds fantastic.
cep89
GX - 1st Gen (2003-2009)
Oct 16, 2021 07:34 AM
kmeehan
May 23, 2019 08:12 AM
boxcarfan
GS - 1st Gen (1993-1997)
Aug 19, 2010 09:51 AM
lamar411
RX - 1st Gen (1999-2003)
May 30, 2010 08:31 AM
JRGS400
Feb 22, 2009 12:59 PM
