Codes and Flashing Lights
Old May 16, 2017 | 08:23 AM
LSDoc's Avatar
LSDoc
Default Codes and Flashing Lights
I addressed this in the forum before and I thought I had the solution, but the problem is back. Even though I replaced the gas cap, I'm still occasionally getting the codes: 0400, 0401, 0406, if I recall the numbers correctly.
Also, I'm seeing my ABS and 'Sport' (Sport suspension) lights flashing most times that I start the car. I have to re-start the car to cancel the flashing lights.
Any ideas???
Thanks, Dan
Old May 17, 2017 | 10:29 AM
LSDoc's Avatar
LSDoc
OK, with all the knowledge base on this forum, nobody has any ideas???
Old May 17, 2017 | 04:38 PM
LS430inDE.'s Avatar
LS430inDE.
Any ideas???
Thanks, Dan
What year LS??? Aren't P0400, 0401 and 0406 all EGR related? I know on 2nd gen LS's the EGR pipe/tube degrades over time, and if cracked/damaged, you can hear an audible exhaust leak sound, almost like a helicopter? Any exhaust sounding leaks? How's fuel economy? Did you scan the codes or someone else?
No fuel additives will clean the EGR valve--you'd need to physically remove it. (I just did a search and there's no TITLES of threads related to EGR valve!) Sounds like a good opportunity for a DYI EGR removal & cleaning procedure!
Old May 17, 2017 | 07:38 PM
LSDoc's Avatar
LSDoc
It sounds like you're on to something. I was possibly mistaken in thinking that those codes were related to a faulty fuel cap? Sounds like I'll have to do a lot more searching.
Now, the flashing ABS and 'Sport' lights are probably another story...
Old May 17, 2017 | 07:41 PM
LSDoc's Avatar
LSDoc
BTW, this is a 2001 LS430 UL.
Old May 18, 2017 | 06:26 AM
LSDoc's Avatar
LSDoc
The latest code I got this morning when starting it was: 0440.
MDames2
Oct 15, 2023 06:50 AM
lexslexus
Jan 15, 2018 05:51 AM
duc_racer
19
Aug 30, 2017 11:09 AM
Jil
Nov 29, 2015 03:55 PM
4double0
Apr 6, 2011 06:35 PM
