Last Call before I buy a whole new A/C compressor
Folks,
just fishing for feedback. I did AC pressure switch and the cooling still works well but only engages intermittently. If I flip on and of several times the cooling kicks in.,
I priced a Denso compressor - does anyone have any additional suggestions before I drop some serious cash on a compressor/install and a full AC recharged???
Thanks in Advance!!
Thanks in Advance!!
KncklFKR13 (07-15-22)
What is the reasoning for not wanting to take it to a shop to diagnose?
I mean, you'v already thrown an expensive repair at it by "guessing" with a pressure switch that required you to take out the freon and recharge it, but it didn't work. You would already be money ahead had you just taken it to place that knows AC systems.
Now you want to put the single most expensive part of the AC system on and hope that fixes it? Do yo have the necessary equipment to properly recharge the system?
I applaud people wanting to make repairs themselves, but there should be some troubleshooting before you throw parts at it and cross your fingers.
Do you have an AC gauge set? What are the low side and high side pressures telling you? Someone that knows this trade could tell you instantly if your compressor needs replacement by hooking it up to some simple gauges.
Sorry for the shorthand, I had a reputable shop scan the cars diagnostics. He did the evac, replaced the switch and recharged the system. Not just going rogue on it.
That seems disappointingly short-sighted.
I'm not an AC expert, although I do have a nice gauge set, a vacuum pump, and a tank of 134. How confident are you in your shop's expertise? Again, I'm not an expert but it doesn't add up for me. Maybe get a 2nd opinion? Do you have a shop nearby that specializes in AC? I don't mean a shop that advertises "We speciaize in: (list of every system on every make of car)." For me, the local expert advertises as a radiator & AC shop.
If a shop recommended a repair, and after doing it the problem is still there, they should eat that cost 100% in my opinion.
Nobody here can say whether or not you need a new compressor because they would need to see it running on a gauge set to make that call. A COMPETENT AC shop though could easily tell you if that was a problem by looking at those readings.
FWIW, ac compressor failure is not a very common problem at all. It could certainly be that but nobody can really tell online without seeing the readings. Again, this isn't something that you should be guessing on, a good shop could show you why the gauge readings indicate your compressor needs to be replaced.
I would just hate to see you go down another wrong path and spend more money.
if you carefully manually engage the clutch by tapping the front of it does the magnet lock the clutch in place? Does it stay engaged untill the next cycle off period or does it immediately disengage?
biacs
05-12-17 04:48 AM
