Is there any particular order in which bulbs fail?
For example, on my wife's car made by GM, it starts around age 3, with the rear lamps on the outside, which handle brake/signal. Then it goes to the front drls. I replaced the right a few weeks ago, the left today. Don't you wish you had $15 for every time you saw a GM car with a bulb out? I think you'd retire 3 years early. If I posted this on my other forum, I'd be banned and the UAW would crawl out of the woodwork.
I cannot prove it, but based on what my wife's cousin says, who works in the business, GM is pretty bad, Fiat Chrysler is the worst. I don't think the bulbs coming out are LL's. I compared, both are Sylvanias in the DRL's, one says 0556 1431 A5, the other, 1835 3470 A7. On rock auto, the LL's cost 55 cents more. Maybe for GM, 5-10 cents?
Haven't done the front signals, or the rear inside park or backup lamp. Any of the other 4 in the rear require the entire hatch to be disassembled, so when that happens, I would do all 4 bulbs with LL's.
Curious if the LS430 has any bulbs burn out other than the 7440 high mount, which is easy. My Maxima only had rear brake/park, and front turns, in 18 yrs. But at year 18.5, the entire right front park and turn signal went out, could be a ground...
