Wires pulled out spark plug connector
Old Dec 20, 2016 | 10:05 AM
wordwrkr's Avatar
wordwrkr
Smile
"Soldering the wires from the new harness to the engine's harness is a PITA! Make sure you use quality heat shrink on each conductor. Trust us, you need to PERMANENTLY fix the wires. We all thought we could 'rig' the connection but only to fail a couple hours/days later!!!! (and you do NOT want to be in the middle of town throwing a code and misfiring!!!)"
My solution, albeit temporary until the new connectors arrive from Amazon, was to disassemble the connector and remove the pins, then crimp and solder each pin onto its wire, and then reinsert the pins into the connector and snap it back into place. And you're sure right: major PITA. And it didn't help that it was cold and pretty dark.
It's a lesson about carelessness and the delicacy of these connections that I doubt I'll have to relearn.
Old Dec 20, 2016 | 10:16 AM
wordwrkr's Avatar
wordwrkr
Unhappy Is that the right link?
Happy reading!!!.... https://www.clublexus.com/forums/ls-...e-shaking.html"
Hey LS430inDe, I read that entire thread, and there wasn't any mention of having to reattach the wires to the spark plug connector.
Old Dec 20, 2016 | 10:22 AM
wordwrkr's Avatar
wordwrkr
Default Well, there's a reason for that
"Your post also said: "I plan to visit the junk yard, cut off the #1 plug connector" ... which is not the one closest to the driver. I'll take some pics of # 7 coil on plug connector and post in a few minutes."
That's because I wrote that before I knew what the heck I was talking about. At that point all I knew for sure was that it was the plug closest to the driver seat, which I have since learned is #7.
And super thanks for snapping the photo for me. It's good to have confirmation that the wires are connected correctly.
Old Dec 20, 2016 | 10:27 AM
Tom57's Avatar
Tom57
This may be more than "temporary," wordwrkr. Others have tried "Rube Goldberg" type solutions that proved to be temporary. Your direct pin/wire crimp and solder is akin to a solid factory connection. Nice work.
Old Dec 20, 2016 | 10:57 AM
wordwrkr's Avatar
wordwrkr
Smile Still a major PITA
Thanks, Tom. The hardest part was figuring out how to get the pins out of the connector in the first place, and not dropping and losing them. Cold fingers make for lots of fumbles, and it's freakin' freezing cold here in Kansas City!
Old Dec 20, 2016 | 07:10 PM
LS430inDE.'s Avatar
LS430inDE.
It's there now!
Old Apr 18, 2019 | 09:18 AM
Alpha9's Avatar
Alpha9
Sorry to bring up an old thread. I’m wondering same thing happened to me when replacing my starter. If I’m looking at the engine standing over it. It’s the right one in the very back. So the coil plug closest to the driver seat.
I need to know the order they go in
tradosauru
Apr 1, 2018 08:36 AM
Jspoors14
GS - 1st Gen (1993-1997)
Jun 25, 2017 03:59 PM
Lexscme
Oct 17, 2009 07:04 PM
1sxyrxy
Jul 8, 2008 09:44 AM
MrHorse
Performance
Jan 24, 2002 06:44 PM
