I have a 2001 Lexus LS430 UL which had a bad rear right height sensor. I had the sensor replaced with a known working unit. Using techstream, I had the codes (bad height sensor RR/ height control solenoid circuit RR) for the air suspension erased but I keep on having the C1739- Height control solenoid circuit RR, error code.
The code will always erase, the air compressor will run, but the code will come back after 30 seconds. I have searched and found nothing in regards to this code, any input or advice would be appreciated!
