Torn passenger side lower ball joint cover
After replacing my front rotors and pads on my 01 LS430, I was informed that my passenger side lower ball joint cover is torn. There is no play at this time or any noises, but of course I understand over time, dirt will get in and deteriorate the ball joint. My question is: How much labor (time) is involved and what must be removed in order to replace the lower ball joint? I have a feeling that it might have been easier if done when my front rotors and pads were replaced...... yes??? 2nd question.... Is an alignment required (recommended) when replacing the lower front ball joints in our cars? Thanks all.
It's a fairly easy job to do. I replaced mine a couple of years ago and posted the steps here...
https://www.clublexus.com/forums/ls-...placement.html
No wheel alignment was required.
Might be worth it to pull off the wheel to see how badly the boot is torn. If it is a small tear you might be able to simply clean the area of the boot around the split and then seal it with some RTV. You wouldn't be able to drive your car for at least 12 hours while you waited for the RTV to cure but it might offer you a low cost solution to your problem...
According to the Auto Repair Reference Center available online through my library the book rate for lower ball joint on this car is 2.5 hours for one side, 3.9 for both.
OMAHA
Dec 19, 2014 12:45 AM
