Only half my tail lights work!
Old Sep 14, 2016 | 09:59 AM
2JZNSHT's Avatar
2JZNSHT
Default Only half my tail lights work!
I have a 2003 LS430 and I switched to LED after market tail lights and the tops of all the lights don't light up. All 4 pieces are the same. Anyone have any ideas? Is there a seperate fuse somewhere for the top half of the lights? I don't get any error messages on my dash but still they don't work... So any direction on this would be greatly appreciated
Old Sep 14, 2016 | 02:37 PM
Coulter's Avatar
Coulter
I would first swap in the old style to see if they all work, but aftermarket led's are usually cheaply made and don't last nearly as long as people would have you believe.
My guess is it's simply defective LEDs and not the car itself at fault.
Old Sep 19, 2016 | 05:28 AM
xsuperjoex's Avatar
xsuperjoex
Double check your wiring. The black wire from the new harness needs to plug into the white wire with a black stripe from the harness you transferred over. I had the same issue, after actually starting the car all of my LED lights work perfectly now.
Toyboy300
Mar 1, 2017 02:58 PM
AKGWBver2
Jul 11, 2015 03:35 PM
af1c331
Jan 13, 2012 03:05 PM
shademand
RX - 1st Gen (1999-2003)
Apr 9, 2010 12:43 PM
21colvera
Dec 16, 2008 02:28 AM
