long delay when shifting into reverse
I've been experiencing a delay of engagement of 4-5 seconds when shifting into reverse lately. It doesn't happen every time I shift into reverse though. It has occurred when the car has been both warmed up and cold. I'm in Miami Beach so it's not cold out at all. The car is an '02 with 175k miles and trans fluid was completely replaced with Toyota Type IV for at least the third time in its life about 6 months ago. What could be the issue?
Transmission solenoid comes to mind.
Originally Posted by Lavrishevo
(Post 9322866)
First thing I would think about would be the condition of the fluid. Since that has been addressed some internal issue? Does the solenoid require a rebuild?
To my knowledge, no rebuild is necessary. Drop pan and replace solenoid. You are sure your fluid level is correct?
2 Attachment(s)
4-5 seconds is a bit too slow. Repair manual says less than 1.5 seconds and suggests some possible causes...
I think it would be worth verifying you have the correct amount of fluid in her before you drop the pan. Also, it appears the solenoids are not related from the info RKW posted.
thanks for the info, I'll check the fluid.
Check out this post for ATF adjustment for the LS430
https://www.clublexus.com/forums/ls-...placement.html |
I see that's for the 04-06 cars. Mine is an '02 with a dipstick. Should I check the fluid when it's cold or after the engine is warmed up? While it's idling or off?
1 Attachment(s)
Sorry, my bad... Please take a look at Item 10.
Just checked the fluid and the level is normal.
Drop the pan, replace the solenoid, clean the pan and replace the filter. seal up the pan and use OEM transmission fluid from the dealer, that should fix the problem.
