Is this sub-woofer comparable with 2004 ML system?
Old Oct 26, 2015 | 06:59 PM
  #31
jpv7774's Avatar
jpv7774
excellent question ...they just had wires coming from the adapter..........one went to pos and the other to neg.......the Pioneer had a push in wire receiver on each tab, hope that made sense. Talking to a guy on ebay right now regarding sub. He is pretty proud of that 10yr old sun faded sub that I will have to re cone.
Old Oct 26, 2015 | 07:50 PM
  #32
Bocatrip's Avatar
Bocatrip
I wasn't aware there were any outfits that are willing to re cone a ML subwoofer. I remember when researching this 5 years ago the only outfit that re coned (don't recall the company name) would do every brand speaker except the ML.I orginally refoamed the sub and eventually when the voice coil in the cone went, I replaced with a new OEM sub for $295. The original cone was completely sun bleached from the black color. Where were you able to find a shop?
Old Oct 26, 2015 | 07:58 PM
  #33
jpv7774's Avatar
jpv7774
Im not looking for a shop to re cone. I dont have a sub. I am in the market for a used sub and if I find one I think I will re cone before I install.
Old Dec 25, 2015 | 05:29 PM
  #34
rich2kbusa's Avatar
rich2kbusa
i just had an experience with this that i wanted to share. I bought the Polk Audio db840DVC and followed a DIY on installation and everything went fine when i turned it on and tested it but after i put the seats back together i went out for a drive and the speakers would all cut out for a second at a time if i turned it up past like 50%. After some research, i took it back apart today (way less time!) and found that i must have had a brain fart when i wired it. i wired it in parallel instead of series like i intended. I rewired it in series and appears to work great with no cut outs in an hour of driving with the music loud. Hopefully it stays well, but if not, i'll check back in.
2003 LS430 ML system
Old Dec 26, 2015 | 11:06 AM
  #35
Tom57's Avatar
Tom57
Dual voice coil wired in series increased the impedance closer to match the OEM-rated 14-16 ohms for the ML sub. Glad you didn't blow the amp at 4-8 ohms.
Trocks797
Apr 23, 2013 06:56 AM
NYC ES3
IS F (2008-2014)
22
Nov 28, 2012 07:19 AM
dealerGM
Jul 29, 2012 02:21 AM
1supra
Nov 16, 2011 02:52 AM
phenomic
Mar 22, 2010 10:43 PM
