rim interchange ?
Old Aug 29, 2015 | 05:35 PM
wdust's Avatar
wdust
Default rim interchange ?
I have a 2003 LS430 with the 17" rims. I found a used set of rims that I like from a 2013 IS250c that are 18". If I use tires that will keep the tire diameter the same for the speedometer/odo can I use these rims? Thanks.
Old Aug 29, 2015 | 09:44 PM
HiloDB1's Avatar
HiloDB1
By the looks of it I dont see why it wouldnt. Only thing you should check is the hub size and that it clears the brake calipiers. The bolt patern is the same and the offset will work.
mjfn
Jun 18, 2019 07:12 PM
BostonVP
Apr 10, 2013 07:03 PM
horent135
Wheels, Tires & Brakes Forum
Jul 23, 2008 08:01 PM
edawg
IS - 1st Gen (2001-2005)
Oct 20, 2001 12:57 PM
