04-06 floueds type
Old Aug 8, 2015 | 06:35 AM
Fixman's Avatar
Fixman
Default 04-06 floueds type
I tried shearching but did not find the info in 1 place.
Qustion, can some post of the fluids type, and capacity of the LS430.
Ex.. Engine oil xx litres SEA xxx.
Power stering oil xx litres ATF Type xxx
Old Aug 8, 2015 | 03:50 PM
Lavrishevo's Avatar
Lavrishevo
Oil is 5w30 and hold between 5 - 5.5 quarts depending on how much is drained. 5.5 quarts is 5.2 liters
Transmission is WS or world standard fluid for model 2004-2006 - Type IV for 2001-2003 about 11 quarts total in the system if I remember correctly l. 11 quarts is 10.4 liters
https://www.clublexus.com/forums/ls-...thread-19.html
Power steering uses Dexron ATF fluid.
Old Aug 8, 2015 | 05:44 PM
rkw77080's Avatar
rkw77080
For 2004-2006 US model LS430:
Automatic transmission fluid: ATF WS
Dry fill: 10.9 liters (11.5 US quarts, 9.6 Imperial quarts)
Drain and refill: 3.0 liters (3.2 US quarts, 2.6 Imperial quarts)
Brake fluid: SAE J1703 or FMVSS No. 116 DOT3
Engine coolant: ”Toyota Super Long Life Coolant”, ”Toyota Long Life Coolant” or equivalent
Dry fill: 9.5 liters (10.0 US quarts, 8.4 Imperial quarts)
Differential oil: Differential synthetic gear oil GL−5 75W−90 or equivalent
1.35 +/-0.05 liters (1.43 +/-0.05 US quarts, 1.19 +/-0.04 Imperial quarts)
A/C Compressor oil: ND−OIL 8 or equivalent
Engine oil: API grade SL, Energy−Conserving or ILSAC multi−grade engine oil, SAE 5W−30
Dry fill: 6.1 liters (6.4 US quarts, 5.4 Imperial quarts)
Drain and refill with oil filter change: 5.1 liters (5.4 US quarts, 4.5 Imperial quarts)
Drain and refill without oil filter change: 4.5 liters (4.8 US quarts, 4.0 Imperial quarts)
Power steering fluid: ATF DEXRON II or III
Capacity: 1.0 liters (1.1 US quarts, 0.9 Imperial quarts)
Old Aug 9, 2015 | 08:04 AM
Fixman's Avatar
Fixman
Thanks that what I wanted to know.
RockAuto
Club Lexus Vendor Marketplace
Nov 30, 2017 12:53 PM
sweet100
Apr 2, 2017 07:13 AM
Rigon28
May 21, 2014 08:02 AM
airahcaz
Performance
15
Feb 11, 2004 08:58 AM
