GUNK fuel injector cleaner
Old Dec 11, 2014 | 08:29 PM
  #46
warminwisc's Avatar
warminwisc
Snake oil, a cobra or a viper. Never used the stuff never any problems, just me man, glad it works for you.
Old Dec 11, 2014 | 10:20 PM
  #47
JoshuaaXD's Avatar
JoshuaaXD
Definitely not snake oil. Its good for injection system because the gas sold today has so much ethonol.
It's common practice to use mmo between races on alcohol powered engines. The same practice is just beneficial on gasoline engines. I mean I only build engines for a living.
Old Dec 12, 2014 | 06:06 AM
  #48
Lavrishevo's Avatar
Lavrishevo
How does MMO compare to Seafoam and introducing it directly into the the induction through the brake booster? Not sure I am a fan of the whole idea as it is aggressive way of cleaning.
Old Dec 12, 2014 | 04:36 PM
  #49
Stu's Avatar
Stu
If the injectors are clogged, from what I have read this is the best ( only ? ) way to really clean them.
My injectors are just 100,000 miles used, so I am just doing a simple cleaning after 10 years. I have decided to add the BG44K to the gas when I get closer to an oil change. I am not having any drive-ability issues - and my gas mileage is normal again.
I will keep a close watch and report after I run the BG44K through the motor and change the oil.
Old Dec 12, 2014 | 06:59 PM
  #50
Lavrishevo's Avatar
Lavrishevo
If anything, putting 1/3 of a can of Seafoam into the intake manifold and letting it sit for 10 min would worry me about fowling a plug or injector.
Old Dec 13, 2014 | 08:40 AM
  #51
JoshuaaXD's Avatar
JoshuaaXD
I don't like seafoam to be honest. That stuff pretty aggressive. You can't really compare seafoam to mmo. Mmo acts more like a lubricant and a light cleaner.
Old Dec 13, 2014 | 08:49 AM
  #52
XJSFan's Avatar
XJSFan
BG44K is great stuff and will not damage anything. I have used it in a good amount of vehicles and it has improved performance and idle quality... Remember though, these vehicles probably needed a cleaning and that is why BG made a difference in the performance/idle.
Shawnmack
Jan 28, 2021 08:23 AM
idoke1
IS F (2008-2014)
29
Apr 2, 2016 12:03 PM
Maserati89
Jun 12, 2010 10:41 AM
Audacity
May 9, 2010 06:37 PM
ALLWiTE2JZ
Feb 23, 2010 03:45 PM
