Aux input in LS430
Old Jul 30, 2014 | 05:48 PM
  #31
empringham's Avatar
empringham
does anyone know if the Vaistech system will work on a 01-03 without nav? (canadian). all the images of the kit ive found appear to only be for ones with nav...
Old Jul 30, 2014 | 07:02 PM
  #32
e60bmw's Avatar
e60bmw
Is the sl3b hard to install? I'm thinking of ordering one, thanks
Old Jul 30, 2014 | 09:42 PM
  #33
forthewin's Avatar
forthewin
Yes, I'm in Toronto.Mine is base system without nav works great...easy install
Old Jul 30, 2014 | 10:52 PM
  #34
aypues's Avatar
aypues
Ya, it was a little tricky. Lookup ls430 stereo removal on Youtube for a tutorial. You'll need those rubberized tools for opening the front stack below the stereo.
Old Jul 30, 2014 | 10:55 PM
  #35
Ears's Avatar
Ears
For IPOD integration, i have a TOYOPD2 ($95.00 in 2010), purchased from ipod car Pros... It has functioned perfectly, was easy to install, and also emulates the MD player (2004 LS430). All vehicle controls function as if it were originally part of the OEM equipment. Only caveat, if you can call it that, is the music must be arranged in playlists 9not a problem for me, I just make a playlist for each artist)
Old Jul 31, 2014 | 08:32 PM
  #36
FlaPhil's Avatar
FlaPhil
Does the Vaistech SL3B output any onscreen data to the base audio system (non SatNav)? Also, that unit does not appear to provide hands free calling on my phone - am I missing that feature somewhere.
The Grom videos show that their unit does display audio data on the base audio system AND has hands free calling. However I'm pretty OCD about tech/audio and , judging from the feedback here, I'm not sure I would be happy with the Grom system.
Old Aug 1, 2014 | 05:25 AM
  #37
greg s's Avatar
greg s
The Grom is supposed to but with me it the audio info never worked right and Grom's response was we're working on an update. I promptly shipped it back.
Old Aug 2, 2014 | 09:25 AM
  #38
FlaPhil's Avatar
FlaPhil
This iSimple unit looks interesting. Amazon price is only $122 - includes handsfree Bluetooth calling and radio display, even in non ML systems
http://www.pac-audio.com/productDeta...&CategoryID=36
I have a local installer who has both Vais and iSimple products. I think a visit is in order.
Old Aug 6, 2014 | 10:42 PM
  #39
Rezonans's Avatar
Rezonans
Is anybony know, where is 5+7 pin connector, in audio system with the screen.
I want to buy ipod/ aux adapter from ebay, it says it feets in 5+7 pin connector, but I have pictures of connectors in the back of cd/cassette unit and back of monitor screen unit, cant see 5+7 pin there.
Old Apr 14, 2018 | 06:41 AM
  #40
HansImmer's Avatar
HansImmer
Hello,
can´t believe to use 6 folders without subfolders and 99 tracks in each. What kind of system is that? Random? AC/DC... 16 Albums. You put all tracks of 16 Albums into one folder? Serious? :-/ Without subfolders such a system is worthless.
I use a Dension DMP3 Harddisk player since 2002. Still working in a MR2 SW20. It has a satellite dislpay (with cord) to put on the dash if theres not a free pace for the whole player. Now i like to put this system into a Lexus LS430 build in 2005 with Mark Levinson Sound System. The Dension DMP3 has chinch (black and red) output. The maual says second solution is to put a Dension FM modulator betwenn the player and the headunit. It will be fitted to the antenna port of the headunit. Guess 15 years later i wont find a used FM modulator.
http://www.mp3newswire.net/stories/2...ionReview.html
http://szamitogep.hu/show/read.php?id=13153
My idea is:
Get one of these Vais, Xcarlink, Yatour adaptors and put the chinch-out of the DMP3 to the aux-in of the adaptor (for example Yatour). How would this look like on the OEM display of the LS430? After this the folder navigation can be done with the display of the DMP3.
Thanks for your help.
Hans
Old Apr 14, 2018 | 08:02 AM
  #41
texan_176's Avatar
texan_176
I put a Grom TOYNA1 in mine. The 3.5mm cable it comes with is garbage so I bought a better one and mounted an aux port in the center console under the 12volt power port. It is completely concealed and I can just throw a cheap MP3 player in the console; listen for hours. My experience with aftermarket bluetooth audio has been not so great in other cars. The sound quality is not CD quality in my case so I kept it low tech and all simple. The Grom part looks like it cost $5 to make but it works great.
Old May 29, 2018 | 02:24 AM
  #42
HansImmer's Avatar
HansImmer
Does anyone choose the USB/Aux-Adapter from Apps2car wiiki-tech.net.?
http://www.apps2car.com/productview/70.html
I tried that one with the 6+6 pin plug:
https://www.aliexpress.com/item/2018...749719103.html
And this 6+6 Y-cable splitter:
Amazon Amazon
Cause the port of my radio (86120-50D40) in the 2005 LS is 6+6 pin:
In some descriptions of the Apps2car adapter is mentioned that the LS430 04-06 is not supported. Same at the Yatour. The text says: LS430 2000-2006: 5+7 pin plug often.
Others like this one list the Lexus facelift:
http://www.amazon.com/Auxillary-Yomi.../dp/B016BD7LKG
Problem:
The blue LED of the adapter is on. I can choose discs of the cd-changer by pressing "disc". There is no car specific note in the manual how to install the adapter and how to use it. I tried to press "disc" twice but can´t get access to the SD-card or smartphone plugged to the adapter.
Seller told me i choosed the wrong adapter. Whats your opinion? Does anyone use this adapter in the car?
Thanks a lot.
Old Apr 20, 2023 | 02:22 PM
  #43
Arterium's Avatar
Arterium
6th Gear
Default Lexus LS 430 2001 ROOF RACKS
Hi there. New here. Anyone know where I can find roof racks for a 2001 LS430? Which brands make them?
Hope I’m posting in the right section. Apologies if not.
Thanks, Arty
Old Apr 20, 2023 | 06:36 PM
  #44
JZZFZZ's Avatar
JZZFZZ
Thanks, Arty
Try Yakima. I believe it took Q towers, 58 inch bars and q75 clips for the old system. Go to their website you might be able to fit their new system.
lws1
NX - 1st Gen (2015-2021)
Nov 14, 2019 06:59 AM
jaybarbara
Jan 4, 2019 07:27 PM
Mydogbella
IS F (2008-2014)
15
Dec 27, 2013 07:35 PM
Old Oiler
Jun 3, 2007 02:36 PM
