audio problem in uk
Old Mar 6, 2014 | 04:39 AM
ceel56's Avatar
ceel56
Default audio problem in uk
hi! from England
I am the proud owner of a 2001 ls430
my car has the mark levinson sound system and I am having the usual trouble with the amplifier not working
one of the club members on the uk forum is kindly having a look at it for me
if it can't be fixed I wondered if there were any aftermarket sound systems that could replace it on your side of the pond?
I have searched and searched over here and found nothing, also to buy a 2nd hand ML amp is so expensive and there is no guarantee that the same thing won't happen after a short while
great forum by the way
regards celia
Old Mar 6, 2014 | 04:51 AM
Lavrishevo's Avatar
Lavrishevo
Going aftermarket requires the whole system to be replaced and you will loose functionality. The most cost effective solution is to either locate a used amp or have your existing amp repaired. Check out the Levinson website for a list of authorized repair facilities and call local electronic repair shops. You should be able to fix the amp for much less the replacing the whole system.
http://m.ebay.com/itm/181336745802?nav=SEARCH
Old Mar 7, 2014 | 10:57 AM
ceel56's Avatar
ceel56
thanks Lavrishevo
i'll not go down that route
ceel
ChuckB669
14
Mar 19, 2025 07:22 PM
bxr225
Dec 12, 2023 01:09 AM
ceel56
Mar 16, 2014 08:23 PM
c21girl
Oct 20, 2012 08:48 PM
Jbthompson
Jun 30, 2012 04:57 PM
