2003 LS430 low speedsuspension noise.
2003 LS430 BASE
High speed I could drive over a pothole and feel nothing but at low speeds it sounds like I have a blown shock over even the most mundane of bumps. However there's no other symptoms of a blown shock maybe a dampening issue but I just bought the car used and I'm not finding a lot of data on this issue.
I'll be doing some exploratory surgery on the front suspension this weekend but any tips or suggestions would be appreciated.
Thanks.
Thanks.
I had similar symptoms. I ended up replacing the front struts and strut mounts with KYB. Problem Solved! If you plan on keeping the car for a while it's a good investment especially for a 10+ year old car. I still do have issues with my steering column making clicking noise and still have not found a fix.
Was there anything obviously worn or broken when you took the parts out something I might look for when I'm checking it out?
Did the shock appear blown when you pulled it off were you able to compress it by hand?
Yaff
Jul 14, 2013 04:36 PM
